Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
motor failure.
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. i have a craftsman 32cc weed eater, on my bike... when i ride (clutchless, pedal start) it idles, then dies. ...
Old 08-18-2009, 10:14 PM
Default motor failure.
dies. it will die instantly if i give it gas. im a newb but i believe it is the needles
IF not let me know
if it is please tell me ... WHERE ARE THEY!??
i looked on the carb, and i see two screws, next to each other, but i don't know if that's them or not.
if it is which is high or low??
the screws are located in what looks like an electrical port.
this is what i think is them
Old 08-18-2009, 10:48 PM
Spunout's Avatar
MB Builder Extraordinaire
Default Re: motor failure..
do have any other pics? this looks like an ultrasound to me
New, fully assembled motored bikes here: http://happytimecycles.wordpress.com/
401-952-7064
Originally Posted by Dan View Post
sn0rk.
Originally Posted by Bikeguy Joe View Post
You are one sick man spun, I like that quality in a person.
A 20-year smoker, I quit smoking with the help of this--->http://www.premiumecigarette.com/415.html a smokeless, non-tobacco electronic cigarette.
Old 08-18-2009, 10:54 PM
FileStyle's Avatar
the high side is usually on the left and the low on right. turn in the left (high) all the way and then back out a couple turns and then turn in the right(low) and back out about 4 turns . that ought to get it going then have to do some tweaking once it's running. the high side should be adjusted after running in a wide open throttle to get the most out of it and then and then the low side for idle to keep it running without dying.
" We cannot live through a single day without making an impact on the world around us. And we all have free choice - what sort of difference do we want to make?" ~Jane Goodall~
Old 08-18-2009, 11:10 PM
deacon's Avatar
minor bike philosopher
you need to take it off the bike wheel to test it. Also check your chokes to be sure it isn't damaged. Check the air breather to make sure it isn't clogged... how old is your gas. All these things can cause the same systems. You are turning the choke off after it starts right.
The choke instructions are to choke it till it tries to start ... half choke till it picks up then turn it off. You did know that right? Thats why whenever I built a WW bike I always had a way to lift it from the bike to start it. Then I lowered it onto the bike after it was running.
Me and the Ebike
New Novel in progress blog...
Old 08-19-2009, 06:50 AM
sorry about the quality... had to be close to get to show you what i mean. i dont know very much, kinda new and my nieghbor helped me a lot.i will giv them a turn tho
Old 08-19-2009, 06:54 AM
i cant lift the wheel , it is pedal start, no clutch. no ripcord. needs the wheel to start
Old 08-19-2009, 07:37 AM
Bikeguy Joe's Avatar
THAT was funny.
Old 08-19-2009, 01:37 PM
deacon's Avatar
You can start those engine with a rope wrapped around the drive shaft. But on the bike it is going to be very hard to adjust the carb. Good luck with your project don't give up;
Me and the Ebike
  #9 (permalink)
Old 08-19-2009, 04:43 PM
wont the rope just whip around? besides i can start it by pedaling... could the carb be just one screw?
  #10 (permalink)
Old 08-19-2009, 04:45 PM
my nieghbor thought it was just one screw.
