Modified 4 wheel rad2go electric scooter
Cabinfever1977
Heres my new project that i use to go to the store with,i also am working on a bike trailer.
1 Rad2Go electric scooter
2 Hkbil 12v 20ah batteries
1 24v 600watt electric motor
1 8 1/2" front wheel
2 8 1/2" rear side wheels: mounted on $3 threaded rod from Lowes
1 8 1/2" rear wheel with sprocket and drum brake
on/off switch for speed control = 20amp house light switch
fuse= Tyco 50v 50amp breaker/toggle switch
standard recharge port mounted on frame and uses standard 24v scooter charger
I also have a plastic milk crate mounted on the rear behind the seat
Handle bar pole was chopped 6"s to be lower
I added the 2 wheels so it will qualify as a handicap scooter to be used on the sidewalk
top speed is around 20mph and im working on making it 2 speeds slow and fast
I was wondering what you were up to. Very inventive!
Definitely will pass for a mobility scooter. 600 watts should be plenty.
Since i got rid of my gas engine kit and got 3 electric scooters.
I scrapped one for parts,made a scooter out of one and made a bike trailer out of the other and i still have my schinn delmar bike,its wore out from having a gas motor on it but it still works and i made a trailer hitch on the rear of the bike to hitch up a scooter trailer im working on. But i found out the second set of batteries i have may be bad,these are the ones i was going to use in the trailer. The set in the scooter are good.
So i might have to buy a cheap set of batteries,they wont be 20ah like the scooter cause that cost too much,maybe 7ah will be cheaper.
