Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
magicalpancake's FELT MP Morini Build
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. So I've finally got around to taking some pictures of my project. The bike is a FELT MP cruiser ...
Old 09-09-2009, 10:06 AM
Cool magicalpancake's FELT MP Morini Build
So I've finally got around to taking some pictures of my project. The bike is a FELT MP cruiser bike model. I chose the S6-T Franco Morini Motori motor which is the 5.8 HP version (comes in 3, 5.8, 10hp varieties). I have used all the information gathered from these forums to make this project so I would like to thank everyone for indirectly helping me.
Currently I have mounted the motor using some custom mounts provided by DEAN at Pipelyne.
The motor mounts didn't fit at first but that was only because I didn't provide the correct measurements for Dean. After getting the mounts back I modified the front mount brackets so the motor would lean back a bit so I could fit the expansion pipe exhaust, which is also provided by Pipelyne.
I decided against putting fuel in the top tube due to the fact I wanted a higher capacity (steel frame FELT cruiser bikes are smaller in the top tube than aluminum versions) and decided on a spun aluminum tank by Coyote Gear (google it!). I mounted the smallest tank they offered from their website. The fuel petcock valve was a brass 1/4 NPC fitting and fuel filter was from a motor bike performance shop.
The tank much bigger than I thought ~ ~ at one gallon capacity.
I actually found working LED turn signals that have a running and brake light for 7-8 bucks from DEALEXTREME.com (spelling?) I'm going to route everything through the frame.
The chain drive was by Ridley Motorbikes. They offer fine made Felt Cruiser motorbicycles that use the china kits and retrofitted with custom mounts/chain tensioners/sprockets/engine covers, etc. I opted to purchase their CNC machined chain tensioner and rear sprocket.
I cut the fender so it would fit. Anyone know what I can line the cut portion of the fender with so it looks nice?
The throttle setup was fairly easy and last night (not pictured) i cut the grip off a china kit twist throttle and slid the stock cruiser bike grip over it (really really hard -_-) I mounted it all up last night and it looks good.
Currently I'm waiting for my front wheel back from the bike shop. I'm having the front hub relaced for a disk brake. Welding up some mounts wont be so hard will they?
I have lots of things left to do, like a wide crank kit (just waiting for sprocket), re-routing ALL wiring/THROTTLE through frame, and well everything else. Ill post more pictures when I have the disc brake mounted.
Old 09-09-2009, 12:15 PM
goat herder's Avatar
Default Re: magicalpancake's FELT MP Morini Build
Looking good Deans exhaust fit that frame nicely. With that sprocket on the rear thats going to be a fast bike better hold on! Nice clean work! That Morini is gonna be fun.
Hobbie shop will have touch up paint for the fender as well as some automotive stores. For the disk brake not sure what you are using post a pict. On my build for the rear disk I will set it up with the caliper locked then weld my mounts. There are some bolt on caliper mounts out there but I am not familiar with them.
One can do anything you set there mind to.... Do a good thing...
Old 09-09-2009, 01:27 PM
Kevlarr's Avatar
You can use the door edge guards they sell for car doors. Nice thing is with the amount you get for a 2 door car even if the chain wears on it you'll have enough to replace it a dozen or so times.
Old 09-09-2009, 05:00 PM
Thanks for the tip!
Old 09-09-2009, 05:04 PM
I was thinking I'd weld up some some tabs for the disk brake after I get my wheel back. We'll see how it goes. I'll probably end up getting a body shop or someplace to get the bike repainted some other color. I guess the bike is some sort of limited edition color scheme called "Rat Pack" or something like that.
Old 09-12-2009, 11:14 AM
Thumbs down Re: magicalpancake's FELT MP Morini Build
Started my motor up for giggles last night. Took a bit to finally get going but once it did it was purring soooooooooo smooth However I have to work out some leaks. The gasket that was supplied to me from Pipelyne is leaking like a sive and so are some welds on the exhaust.
I've been waiting for over 2 weeks for a sprocket for my wide crank kit (from pipelyne). It has a fitting that looks like a hexagonal shape so the sprocket doesn't spin when you crank after it's tightened down. Can this be picked up any bike shop?
I'm patient but it's starting to wear thin. THat is with my bike running. Dean at Pipelyne is cool but I wish he was a bit more organized ~ ~
Old 09-29-2009, 09:02 AM
how did you wire up your lights?
Old 09-29-2009, 07:12 PM
Dan's Avatar
Dan Dan is offline
Wow, awesome MB.
Originally Posted by NEAT TIMES View Post
looking In The Sky, May See Dan Flying By!! Ha Ha Ron
I want 2 ride my bicycle
  #9 (permalink)
Old 10-01-2009, 01:57 PM
I ordered a light kit from DEALEXTREME and did the wiring through the frame of the bike. It's battery operated and housed within the lights.
Wiring it through the frame was a pain ><
  #10 (permalink)
Old 10-01-2009, 07:45 PM
Talking Re: magicalpancake's FELT MP Morini Build
Originally Posted by Dan View Post
Wow, awesome MB.
Thanks! I'll be posting pictures of it soon. I'm 98% done. Just have to weld on the disc brake mount on the front fork.
Runs strong.. the gearing is a bit tall though. With the centrifugal clutch it took me awhile to realize the stock motor air intake was too restrictive for the gearing I had. 40 sprocket in the rear. Slow accel but I'm cruising at a pretty low rpm at about 40mph. I pushed it a little and I could easily pull 50 and it would seem a bit more to go ~ ~
