| | | DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds | Lifan with a bar mounted shift system, possible? Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. I've just had an idea,
How about a semi auto lifan with the gears being controlled by a regular ...  |
11-05-2009, 01:11 AM
| | Motorized Bicycle Senior Member | | Join Date: Jan 2008 Location: England
| | Lifan with a bar mounted shift system, possible? I've just had an idea,
How about a semi auto lifan with the gears being controlled by a regular handle bar mounted thumb shift. some sort of armatures off the end of the gear shaft with your right hand operating up and your left hand operating down. The rachet system with in the levers would need removed. Or because a lifan (or at least sum) have that strange gearbox where you shift up (or down by foot) from forth and it takes you straight back to neutral, meaning you could do it all with just the one lever.
What do you think?
I know lifans are wide but the are always ways around that, btw how wide are they? |
11-05-2009, 08:54 PM
| | Motorized Bicycle Senior Member | | Join Date: Dec 2008 Location: iowa
| | Re: Lifan with a bar mounted shift system, possible? but id you want to downshift then you need the second lever |
11-05-2009, 09:07 PM
| | Re: Lifan with a bar mounted shift system, possible? Does a lifan not go N-1-2-3-4-N-1-2... I have never used one was only told, is this correct?
if not scratch that, two levers will have to do, or a modified single lever with two different pulls. |
11-07-2009, 09:54 PM
| | Re: Lifan with a bar mounted shift system, possible? some ten speed bikes had a solid wire type cable shifter didn't have spring return the cable would push the derailer, something like that would work |
11-08-2009, 07:37 PM
| | Re: Lifan with a bar mounted shift system, possible? Sounds like a good solution to me, maybe a project to deal with after my current one 50, 70 or 88cc (depending on widths) lifan with bar mounted shift. |
11-09-2009, 08:13 PM
| | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: Alabama
| | Re: Lifan with a bar mounted shift system, possible? I am working on something similar, but I bought the full auto. I didn't want to shift. How lazy can I be? The engine is about 12 inches wide. |
11-09-2009, 11:11 PM
| | Re: Lifan with a bar mounted shift system, possible? sounds cool, what size is it that is a full auto? I havn't yet come accross a full auto |
11-10-2009, 08:43 AM
| | Re: Lifan with a bar mounted shift system, possible? 50cc 4 Stroke Engine for Mini ATV Auto | GIO
Here is the link to where I purchased mine. It is a 50cc. |
11-10-2009, 09:06 AM
| | Re: Lifan with a bar mounted shift system, possible? Woops! Looks like the link had the cc size. Anyway, when you searching for engines look for atv engines. A lot of them are full auto where the dirt bike and pocket bike engines are manual or semi auto. |
11-17-2009, 09:54 AM
| | Re: Lifan with a bar mounted shift system, possible? Here's my stretch and the 50cc auto that I'll be working with during the cold season. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:39 AM. | | | Sponsors
