Re: key vs set screws? Spider,
You did right by installing the set screws at 90 degrees. They should hold just fine. If you want a little extra assurance look for set screws with a knurled point on them. They will "bite" into the shaft better than the flat ended ones. They make taking things apart a little harder because they leave a rough place on the shaft but they hold. Go for grade 8, not stainless.
As with anything with threads that you want to hold use a thread locking compound. Loktite makes many products for this purpose. I use it for everything that I don't want to vibrate loose and I use neverseize on things I don't want to stick, like spark plugs.
Good luck and easy ridin'
Over Youth and Skill |
