Originally Posted by brucemg51 I'm guessing you mean that if you lock the engine down rigidly with slotted mounts, it can't move with the bumps, which it could with springs and turnbuckles. |
If you mount a motor to the frame and the motor mount is welded or bolted to the frame and can't move, well, the tire is also mounted to the frame and can't move, so how would the motor/drive roller be affected by bumps? I would think that only a foreign object like a rock would be the only thing that could affect the motor's contact with the tire and even then, the tire would give enough to not affect it except for a short, quick bump depending on the size of the rock. But I know you have to have to be able to engage and disengage it but it still seems everything should stay in place on bumps.
