| | | DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds | Homelite Super XL 925 Chainsaw Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. I want to use this engine since it is a 24" bar chainsaw and too much for me to ...  | |
05-21-2008, 11:27 AM
| | Motorized Bicycle Member | | Join Date: May 2008 Location: CoMo (Columbia, MO)
| | Homelite Super XL 925 Chainsaw I want to use this engine since it is a 24" bar chainsaw and too much for me to use in the city. and since it is just sitting around I though wouldn't that be great on a bicycle. And here I am posting a thread. Never done this before but am more than willing to give it a go.
thanks for any help that I can get.
Jonas AKA Neko |
05-21-2008, 12:23 PM
| | Re: Homelite Super XL 925 Chainsaw You'll probably need a gear reduction. I bet that homelight turns rpm's....................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
05-21-2008, 03:51 PM
| | Re: Homelite Super XL 925 Chainsaw Mount up a centrifugal clutch with a #41 size sprocket of 9 teeth and mount the engine to the frame. Then install a 48-50T sprocket on the rear wheel, and connect the two with a #41 chain.
That'll get you started.
05-22-2008, 10:23 AM
| | Re: Homelite Super XL 925 Chainsaw Thanks for all the help. Guess I would go to thats dax for the parts? |
05-22-2008, 02:34 PM
| | Re: Homelite Super XL 925 Chainsaw You can buy a rear sprocket kit from any one of several sellers on ebay or with links here on the left.
#41 chain is available at Tractor Supply Co. or similar stores, motorcycle/mower/toy shops.
You will have to brainstorm up a mount for the bicycle motor that will allow a clear shot to the back wheel/sprocket. You'll have to modify the throttle and make sure you have adequate brakes, you'll need them. Don't be afraid to modify/remove/adjust the cover over the clutch on the power unit.
Git buildin'!
07-13-2008, 03:29 PM
| | Re: Homelite Super XL 925 Chainsaw Hello and thanks for all the help. I have since bought a chinese motor off ebay other than the clitch handle being really cheap and broke durring install all went well was riding the same day. I go t help for you guy with the kill switch thanks alot. This winter I am going to try and get the chainsaw installed on a bike just got to find the right bike. LOL  |
07-13-2008, 03:33 PM
| | Re: Homelite Super XL 925 Chainsaw Thanks for the update, something we should all try to do more often.
It's always good to know how things went, even if they are going anywhere right now.
08-02-2008, 08:56 PM
|  | minor bike philosopher | | Join Date: Jan 2008 Location: north carolina
| | Re: Homelite Super XL 925 Chainsaw I second the need for updates. I am guilty of going the other way and doing too many progress reports on a project. I really am curious to know what worked when a member has a problem and gets ten different suggestions. |
10-18-2009, 01:23 PM
| | Motorized Bicycle Newbie | | Join Date: Oct 2009 Location: arizona
| | Re: Homelite Super XL 925 Chainsaw ok
how do i do that |
10-18-2009, 01:26 PM
| | Re: Homelite Super XL 925 Chainsaw hello i am Lance Coats out of Chandler AZ | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:20 AM. | | | Sponsors
