Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Home built start tips nedeed?
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. I Live In Los Angeles and Im interested in building a Motorized bicycle for my work commute. My truck cost ...
Old 09-21-2008, 07:40 PM
Default Home built start tips nedeed?
I Live In Los Angeles and Im interested in building a Motorized bicycle for my work commute. My truck cost me $10 gas round trip, Bus $1 but to long. The first 10 miles are a pretty straight level shot from work, aside for one overpass, but the last 3 are over a pretty steep hill. I'd like to ride the bike up to the base of the hill then catch the bus over the hill. If i take the bus the whole way home It side tracks and i have to catch a transfer.
What would be a good recommended setup for a home build? I'd like to go with a full suspension setup but im not sure which motors are the strongest to get me over some inclines and keep me at a decent MPH. I'd like to stay within a $200 range for the motor setup. There are tons of yard sales here so I don't think i will have a hard time finding a bike for under $40 and Craigslist is on my computers favorite list. I don't mind buying used either, what ever it takes to save a buck but the more power the better i would think.
Also, i would like to keep the noise level down, im not a big fan of the guys whom you can hear coming from 2 blocks away and 3blocks after they have already passed.
Any advice would be greatly appreciated.
Thank You
Oh Yah, I do custom metal work and I am very mechanically inclined.
Old 09-21-2008, 08:51 PM
deacon's Avatar
minor bike philosopher
Default Re: Home built start tips nedeed?
If you are tied to full suspension I recommend a 31cc ryobi weed whacker mounted on the front of the bike. Rear mount is a pain I just tried to get on working for two weeks. every time you move the throttle cable changes length.
31 cc if you don't mind pedaling some will work pretty well.
If you go with a hard tail bike, I would say a 42 cc chainsaw is a good engine to use. I haven't thoroughly tested mine yet but I am very impressed so far with what I have done.
Let me know if I can help. In all fairness I should add that you can buy a china kit for 200 bucks.
Me and the Ebike
New Novel in progress blog...
Old 09-21-2008, 09:07 PM
Im pretty sure he will get in trouble with a china kit in california, epa restrictionsa on 2stroke engines
Old 09-21-2008, 09:23 PM
deacon's Avatar
I didn't think but you are probably right. Maybe he can get hold of one of those new four stroke weed whackers.
Me and the Ebike
Old 09-22-2008, 12:40 AM
Thanks, i think im going to go with a hard tail and just setup a soft seat.
Whats the difference in the small 2 stroke motors and 4 stroke motors? another concern is the noise factor. can the 2 stroke chainsaw motors be baffled without losing to much of the power?
Also, are there any other suggestions for motors above 42cc?
Old 09-22-2008, 05:55 AM
Talking Re: Home built start tips nedeed?
My Ryobi is California compliant. FOr lawn work, I'm not sure for the roads.
IF you are looking for cheap and reliable (once you work the bugs out) a WW is the way to go. depending on how steep those hills are the ww may be able to pull you up them. Mine is almost able to pull the hills even with my fat butt on it. Your weight will be the main limiting factor with a friction drive. And you will pedal somewhat. I don't pedal hardly at all except for the start up, major hills and when I'm trying to keep my speed a constant.
A WW I'm sure can be muffled with a scooter pipe, but I have yet to try it. I took a look at the GoPed that I have in the garage and the ryobi and the size and shape of the exhaust port is the same. So I'm thinking if I work it right I'll be able to get one of those fancy goped pipes and really quiet it down. Right now that is the only draw back of the WW is that it is a little on the loud side, course I also drilled a couple of small holes in the exhaust.....
Also a WW is so small you could conceal it easily. The ryobi I have weighs just a few pounds, I've got it on what I call "quick release" 3 screws hole it to the frame, the extended kill switch plugs in via an earphone jack and I can disconnect the throttle in about 2 seconds. You could easily set it up so that the ww is inside a crate, basket or some sort of frame work. There is a thread somewhere- possibly the other forum (ick) about just that. Anyway if you put 2 milk crates one on either side like saddle bags, you could pretty well hide the WW. OF course the noise is going to be the issue.
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 09-22-2008, 07:26 AM
deacon's Avatar
Like shoes I drilled all my mufflers except the 42cc chainsaw. Now it may just be me but I think the 42cc chainsaw is much quieter than any motorcycle on the block. It is a gasoline engine you are going to have noise from any of them. It's just how much is acceptable to you.
I paid $35 bucks for my 42cc engine on ebay and it needed nothing but some case modifications to work on my bike. I did have to get my neighbor to weld the clutch nut onto a drive wheel for me.
I will try to hill test the 42cc today so that I can give you a hill climbing opinion about it.
Shoes talks about pedaling to keep the speed up but I can't do that my bike has the chain ring from a 20" bike so I can't catch up to the motor unless it is on a big hill. I do have to pedal mine on long or steep hills. Not the 42cc yet but I haven't put it on the big ones yet either.
I need to do some more work on the clutch then I will test it. If I can get that done today I will have an answer for you.
Me and the Ebike
Old 09-22-2008, 02:53 PM
Great, Thanks Guys. not sure what a WW is but i will do a search.
I think my only concerns with a friction would be tire wear and the fact that its side mounted. Are the motors that are mounted on over the rear wheel better for the bikes balanceing point.
I look forward to your test Deacon, I way about 145lbs. so I think i should do okay for the farely not to steep hills.
One other question. What is the difference between a Ryobi like motor and the motors that are set in between the frame rails with the long cylinder, like the Expedite 60cc which is sold by ThatsDax? Like the bike in the pic posted.
  #9 (permalink)
Old 09-22-2008, 03:44 PM
deacon's Avatar
Ah you do need help...
The two stroke in the photo is from the china kit. Cost between 150 and 200 for the kit. You can do what you want including climbing that hill on the way to work with one of those. I have no idea if you will get stopped by the smog police or not. Possibly you will.
A WW is a weed whacker They come in all sizes both 2 and 4 stroke these days. What most of us (who build with them) are doing is buying them is buying them used for about twenty to thirty bucks. The ryobi is a brand of weed whacker also they make engines for several other brands. You want to get at least 30cc I think.
Most of those are mounted on the side and the drive wheel hangs over the tire held down by a spring. In do it yourself you literally have to do it yourself. Build your engine frame and everything else you need to do.
DYI motor bike/ bicycle booklet email delivery - eBay (item 230293979780 end time Sep-29-08 10:31:37 PDT)
That is a complete set of plans for a do it yourself motor bike using the the weed whacker.... I think they are great 1st bike plans if you are not going to use a kit. However I have to warn you they are my plans. I am not trying to sell you plans. I will be happy to help you along the way to build yours it isn't hard.
I spend all day testing the 42cc chainsaw bike today. The results are here Ridin' DIY the last entry except I am about to make a new entry now on a different bike which is the 31cc WW bike built with the design in the plans and the one I recommend for a first bike.
Me and the Ebike
  #10 (permalink)
Old 09-22-2008, 04:23 PM
Great Deacon, thanks for the advise. Duh! WW= Weed Wacker, My Bad. I just stumbled upon this site within the last few days looking for an alternative way home and now im like a sponge. Thanks for the plans link, I don't see anything wrong with making a buck doing what you love.
I looked in the WW and so far have only found at most 30cc. I would like to go with at least 40cc but there isn't much in the local craigslist that aren't under $75. I'll keep the search on and touch base once I get some leads.
Thanks again.
