Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
HELP!!! 5.0hp Chain Drive Rack
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. Ok so i have a big 5hp motor but it spins the wrong way meaning i would need to mount ...
Old 07-10-2009, 08:13 PM
Exclamation HELP!!! 5.0hp Chain Drive Rack
Ok so i have a big 5hp motor but it spins the wrong way meaning i would need to mount it with the gears on the left side it uses a #35 heavy duty chain. So i need to find a way to mount my drive gear on the left side
please help!!!
Last edited by derekfrelow : 07-11-2009 at 12:26 PM. Reason: needed details and was generaly bad
Old 07-11-2009, 12:26 PM
Default Re: HELP!!! 5.0hp Belt Drive Rack
Here are some photos showing a Timing Belt Pulley being set up on a Single Speed Disc Brake Hub. Is this the type of thing you are asking about?
ocscully
help-5-0hp-chain-drive-rack-adapter-014.jpg  help-5-0hp-chain-drive-rack-adapter-016.jpg  help-5-0hp-chain-drive-rack-adapter-017.jpg  help-5-0hp-chain-drive-rack-adapter-019.jpg
Old 07-11-2009, 01:49 PM
Default Re: HELP!!! 5.0hp Chain Drive Rack
dammit i meant chain thanks any way
can an admin change the name of this tread please
Old 07-11-2009, 05:13 PM
Cabinfever1977's Avatar
you can bolt a #35 chain sprocket the same way,either bolt it to the spokes or the wheel hub or adapter.
Go Kart Sprockets & Mini Bike Sprockets
Steel Sprockets for #35 Chain
Results for Roller chain & sprockets:#35 Chain Sprockets
Old 07-11-2009, 07:15 PM
thanks!
do you know where i can get an adapter?
Old 07-11-2009, 07:41 PM
they have some on the sites listed above but they may be for dirtbike or gocart axles.
or try these sites,but your #35 sprocket holes need to match bolts on adapter,you may need to drill holes on you sprocket to match.
ENGINE_KIT_PARTS_PAGE_2 spoke mount rag joint mounting
SPROCKET ADAPTER clam shell axle mount
Old 07-12-2009, 12:32 AM
thanx alot lots of help
