Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Chainsaw Center Mount Chain Drive
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. Ok, so i have received a 46cc poulan pro chainsaw, disassembled it, had a 12t sprocket welded to the centrifugal ...
Old 07-23-2009, 02:29 PM
Talking Chainsaw Center Mount Chain Drive
to the centrifugal clutch drum and am planning on putting it on a 20" bmx bike. I have a few Q's
for you guys. 1) What would be a good gear ratio for this motor with the 12t sprocket? It has
plenty of power + i only weigh 110 pounds (14 yo), also the unloaded rpm rate of this saw is
13500 rpm. 2) Because the engine is right side drive, i want to be able to move the pedals to
the left side of the bike, this will work except for the rear coaster sprocket, it will spin the wrong way, what can i do to make it spin the other way, or do i have to buy something else? Also if you could suggest some good chainsaw mount ideas id appreciate it.
Thank you and all constructive criticism is welcome.
Old 07-23-2009, 08:08 PM
Default Re: Chainsaw Center Mount Chain Drive
gear ratio should be around 12:1
Old 07-23-2009, 08:50 PM
I calculated 13:1 with a 39t rear sprocket. Is this ok?
