Re: centrifugal clutch mods i cant see any real advantage to your clutch engaging at a higher rpm .
personally i think , the combinatin of the size of the motor and the gearing sets the limit of what you can do , without having gears you can change .
i think the only thing you are going to do by changing the clutch rpms is cause your clutch to heat up faster , since your gearing hasn,t changed , your motor will still have to move the same amount of mass with the same amount of power from a standing start . everything beyond that is just clutch slippage and heat generation .
anyways , thats how i see it . its a trade-off , low end power for top end speed
and don,t forget , you will also be increasing the slowest speed at which you can ride under power . eg: if now your bike will drive say 10 mph slowest speed , after you change the clutch you might be at 15 mph slowest speed .
that means now you have to pedal under everything less than 15 mph instead of 10 mph .
i think a clutch should engage at the lowest rpm possible without stalling out the motor
