| | | DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds | BMX Build Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. Thanks Radmanfly, it confuses me as in Australia we dont talk inches, feet & miles anymore we have convereted to ...  | |
08-10-2008, 10:36 PM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Adelaide Australia
| | Re: BMX Build Thanks Radmanfly, it confuses me as in Australia we dont talk inches, feet & miles anymore we have convereted to mm & kmh, anyway thanks for the saftey tips as I wouldnt try to do those rpms or speed, Im really building the bike for torque so I can pop monno's down the street & just for a laugh when I come up at the lights against 50cc scooters i want to scare them lol.... |
08-10-2008, 10:49 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jul 2008 Location: Oswego, NY
| | Re: BMX Build Oh, monno's...wheelies! Now I see. You will need lower gears for that I'd say. Keep us posted! |
08-10-2008, 11:13 PM
| | Motorized Bicycle Elite Member | | Join Date: Aug 2008
| | Re: BMX Build Brains, let's test these gear ratios. Use an 8-tooth drive gear and 74-tooth sprocket, so you can make adjustments using 7t and 6t sprockets. With 8t, you have 9.25:1 gearing. Now create a jackshaft, using 36t sprocket on the hub and 16t on the jackshaft. Jackshaft ratio is 2.25:1. Multiply by 9.25 gets you 20.8:1. Using an online gear ratio calculator with 20" wheel gets you 64 kilometers/hour(40mph) at 14,000 rpm. With a 9t, speeds are 72kph(45mph) at 14,000 rpm.
For more low end, install 7t sprocket, which gets 10.57:1. Multiply with jackshaft 2.25 results in 23.78:1, and 56kph(35 mph). For even more low end, install 6t for gear ratio of 12.33:1. Multiply by 2.25 for 27.74:1 and speed of 48 kph(30mph).
All speeds at 14,000 rpm.
If someone can suggest an online calculator, Brains can work out more gear ratio combinations. It's good to start with 8t drive sprocket, because you can adjust up to 10t and down to 6t.
Good luck.
08-11-2008, 01:14 AM
| | Re: BMX Build Thanks 5 - 7 Heaven, when I get home tonight Im going to suss out if I can get diffrent toothed sprokets as per your suggestion as I will be able to feel & see the diffrence in performance from swapping from one to another, I got heaps to do before I can give it a test drive, got what I need for the accelerator cable now & need to weld the brake carriers back as I cut them off as they were a bit to close for comfort in regards to the chain & still have to devise a chain tensioner as well, will post some more pics as I go along & just worked out that my camera takes video's, so will try this tonight & see how clear it comes out and if it does I will upload on you tube so you all can hear at least how it sounds, thanks a million all you have forwarded great material for me to become more understanding on how to calculate my gear ratio's as this takes a lot of the guess work out now, and should be able to be around the mark from the word go |
08-11-2008, 09:54 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: BMX Build Wow, this is a nice build. You've got some skills Brains.
Can't wait to see this thing all buttoned up and working. Gonna be a monster. Would be pretty sweet to get one of those motors frame-mounted.
Just curious on your home made pipe bender you mentioned - any pics of the setup? |
08-11-2008, 11:28 AM
| | Re: BMX Build Thanks Jasonh, glad you like it so far, and your in luck you will see a build with this motor which will be frame mounted, I have an OCC stingray my dad got from a garage sale & its pretty rough in condition but its all their & original, as its got a 4 1/2 inch rear tyre this motor will work really well with the drive shaft offset it has & should rig up nicely & still retain its original working pedals as well, Im going to go a bit harder on this by putting NOS on it, should be a cracker of a build, I will start this one as soon as i finish this build which should be in about a week, so keep an eye out for the post |
08-14-2008, 09:23 AM
| | Re: BMX Build Ive finished basically this build apart from cleaning the frame up and then putting it into paint, putting it all back together neatly & hiding all the wires through the frame which i have already drilled the holes to feed them through.
Ive attached some of the latest pics, shows the chain tensioner I made up & a pic from the rear showing the chain offset and how its connected, had to machine out some of the rear frame legs to attain good chain clearance & then filled them back up with solid weld as I had to cut through the tube, this will ensure its retained its strength.
I have also taken off the original muffler I made & then re hashed an old exhaust I had to fit, it sounds a lot smoother now at idle but really performs a lot better through the rev range, I like it better
The test rides went really well & it pulls away with ease from a standing start with no help via the pedals so what ever (actually never used them to date), have done about 50 laps of my block & its sweet as, I must be doing around 60km/hr easy as thats the speed limit on local roads & Im passing cars, the look I get is unbelievable with the motorists, it has heaps in it still even at this speed, have not yet really pushed it to its maximum, but I still will try another carby set up I have on the weekend, it will be interesting to see what if any gains it makes, it feels really strong & secure when riding it
I have attached some pics for you all to see thus far |
08-14-2008, 09:25 AM
| | Re: BMX Build Some more pics of my little build |
08-14-2008, 09:53 AM
| | Re: BMX Build That turned out great! Are you getting enough low end power for monnos? (A bigger gear on the rear wheel would help if not) Might have to put a wheel on the tail pipe! Looks really cool, nice job! |
08-14-2008, 09:57 AM
| | Re: BMX Build Dang, that turned out pretty sweet. Good job. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:47 PM. | | | Sponsors
