| | | DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds | BMX Build Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. Some updates on todays build, finish welding in support bracket for the engine cradle, & after putting the motor back ...  | |
08-10-2008, 07:07 AM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Adelaide Australia
| | Re: BMX Build Some updates on todays build, finish welding in support bracket for the engine cradle, & after putting the motor back on and checking clearances with wheel properly mounted I noticed the clearance between tyre & bottom of carby was minimal , about 3mm, out with the grinding tool & cut back to allow a little bit more space between the two, have attached a pic on the free wheeler set up as I was asked if it was a flip flop hub, & you can see how I machined up 2 spacers to get the sprocket to line up and all, this was tricky but in the end the result was what I was after, I made up a temp fuel tank holder so we could give the little beast a kick in the guts & also a temporary throttle assembly as I have to make up a throttle cable to reach the handle bars, cranked it over slowly for 2 pulls with the choke on to get some fuel into its guts, & then it roared to life on the first quick pull I gave it, boy was it awesome, Its got some torque, just tapped the throttle from idle and the whole bikes rear end moved across on its own, the chain wasn't attached as yet though as still cant find the split pin, its actually scary just listening to it, it sounds sick, I'm going to borrow a mates video camera so I can post on you tube for you all to hear it, cant wait to finish the build and take it for a test ride, before we strip it and get it ready for the paint |
08-10-2008, 11:31 AM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Northglenn,Colorado
| | Re: BMX Build You got mad skills. Did you do the welds?
Very nice indeed.
__________________ You have found the fountain of youth. Ride and forever stay young. |
08-10-2008, 12:01 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jul 2008 Location: Oswego, NY
| | Re: BMX Build Wow, make sure the brakes are working, you're gonna need em! Judging from the gearing you're gonna have serious top end....can't wait to see it go! |
08-10-2008, 04:29 PM
| | Motorized Bicycle Elite Member | | Join Date: Aug 2008
| | Re: BMX Build Very nice build, Brains. I admire your work.
Unless I'm wrong, you need a jackshaft and more gear ratio to get the engine to work decently. Using stock 6-tooth and 68-tooth sprocket, that amounts to 11.33:1 ratio. You might want 28.33:1 gearing. |
08-10-2008, 05:49 PM
| | Re: BMX Build Yeah, I was going to wait and see what happened, but I agree w/ 5-7Heaven. You'll burn up your clutch pretty quickly like that (your clutch springs only have to get real hot once and they will loose tension and not work right) and you may never see top speed, which would be about 90! Divide your larger gear tooth count by your smaller gear count and divide by the engine rpm....(about 265 rpm @3000) that's how many rpms your rear wheel will be turning if your centrifugal clutch ever engages. Convert your rear wheel circumference into feet and calculate how far you'd travel in a minute. Times by 60 to get MPH. You'll be scared. Shoot for above 18:1 to get any low end at all, and with that monster engine, I think 28:1 or so would give you best of both worlds, awesome torque and scary high end. Let us know if you want help crunching the numbers to select the right gears.
Reason: math correction
08-10-2008, 07:03 PM
| | Re: BMX Build I don't know if I'm right....someone help me double check this, but using 5-7 H's ratio...."Using stock 6-tooth and 68-tooth sprocket, that amounts to 11.33:1 ratio" as an example, and a 20" tire with a circumference of 5.25', at 3000 rpm it would turn 265 times a minute which is 1391.25 feet. That is 83,475 feet an hour. Divide by 5280 ft and get 15.8 mph at 3000 rpm. (not my original guess of 90) That would be ok. Is this right? |
08-10-2008, 08:14 PM
| | Re: BMX Build Wow thanks guys, Im all confused at the moment with all the above gearing mathamatics, the front sprocket is 6 tooth & the rear sproket on the bike at the moment is 74 tooth, I can tell you guys that the engine revs to 14,000 rpm though!, I have also an 80 tooth rear sprokect which I can use, at the race track they use the same gearing I have installed at the moment & with the same diameter wheel, but now one there can tell me what speed they get as they reckon they havnt got time to look & they dont have speedos, but when Im standing there they go past mighty quick, one of the blokes there stated that I should use a 80 tooth rear sproket, so I was going to give this set up a go & see what happened as well, if you guys could help me with the calcs with these mentioned sproket sizes I would really appreciate the assistance, and it will teach me how to do it myself as well, my dad tought me how to weld & Ive spent a lot of time practicing, thanks for the comments on my welding I try my hardest to get a super clean weld as this helps out when I paint as I dont have to use bog. |
08-10-2008, 08:56 PM
| | Re: BMX Build Quote:
Originally Posted by Brains Wow thanks guys, Im all confused at the moment with all the above gearing mathamatics, the front sprocket is 6 tooth & the rear sproket on the bike at the moment is 74 tooth, I can tell you guys that the engine revs to 14,000 rpm though!, I have also an 80 tooth rear sprokect which I can use, at the race track they use the same gearing I have installed at the moment & with the same diameter wheel, but now one there can tell me what speed they get as they reckon they havnt got time to look & they dont have speedos, but when Im standing there they go past mighty quick, one of the blokes there stated that I should use a 80 tooth rear sproket, so I was going to give this set up a go & see what happened as well, if you guys could help me with the calcs with these mentioned sproket sizes I would really appreciate the assistance, and it will teach me how to do it myself as well, my dad tought me how to weld & Ive spent a lot of time practicing, thanks for the comments on my welding I try my hardest to get a super clean weld as this helps out when I paint as I dont have to use bog. | Wow, you're on the right track. Let's use the 74t sprocket. The ratio with the 6t primary will be 12.33:1, that is every time your crankshaft turns 12.33 times, your rear wheel turns once.
I don't know what the rpm will be at high speed under load, let's say 10,000. To get the rpm of your rear tire divide the rpm of the crank, 10,000 by 12.33. You get 811 rotations per minute.
This is where we need the circumference of the rear tire. Mark the tread and use a measuring tape or roll it on the ground to measure the outermost circumference around the tread back to the mark. (To estimate a 20" BMX tire, multiply pi times dia. which is 20".... stay with me here....a 20" tire will be 3.14 X 20" or 62.8" around. Now divide by 12" in a foot to get 5.23 feet that a 20 inch tire will roll on the ground from mark to mark, double check yours this way too.)
Ok, now we multiply 5.23 feet per rotation to 811 rotations per minute. You get 4241.53 feet traveled in one minute. In 60 minutes, you will go 254491.8 feet. Divide this by 5280 feet in a mile, you will be going 48.2 mph at 10,000 rpm w/ a 20" wheel.
Pretty cool huh? Are you seeing this? Is your tire 5.23 feet per rotation?
You can vary the rpm's and tire sizes and gearing to see what your speed will be if you were to twist it to 14000 under load. |
08-10-2008, 09:42 PM
| | Re: BMX Build Thanks Radmanfly, the steps you have given me are great, I dont understand all the logic behind it but from the steps you have given me I can get the end figure, when i get home tonight (Im at school & during my lunch break of course) I will check the tyre rotation & post it for you to double check my working out, really appreciate all the time you have taken in explaining this to me in such detail |
08-10-2008, 10:11 PM
| | Re: BMX Build No problem, I invite others to double check as I may be going the long way around the cow!
But I think these steps are easy to follow logically anyways to learn how to do it. Just converting engine rotation into tire rotation then tire rotation into linear feet and spreading it over a mile to get mph.
If you're into racing and trying to get top speed, that's where it really gets fun because 14000 rpm is only top rpm. In there somewhere is a sweet spot (the power curve) of the engine. Gearing it to take full advantage of the high end of the power curve is what you are shooting for. Have fun but be careful. 45+ mph on a bicycle is fast! I hate to be a kill joy but if your chain falls off at that speed, and it will, lots of damage can occur to your engine, your bike and you or others around you. It was never meant to be pushed like that. Judging by your other projects, you know where to watch out. Sorry I get carried away sometimes. Have fun! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:48 PM. | | | Sponsors
