| | | DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds | Bearing troubles :( Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. Hi guys
Er dunno what you can suggest but, i just dismantled a chainsaw engine (no idea what make) to ...  | |
09-09-2008, 02:46 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2008
| | Bearing troubles :( Hi guys
Er dunno what you can suggest but, i just dismantled a chainsaw engine (no idea what make) to replace the gaskets, and took got as far as the crank housing, and all the bearings fell out on the con-rod linkage. I gathered them up, but am now stuck as to putting them back in!
Can you suggest anything?
Cheers |
09-09-2008, 02:56 PM
| | Re: Bearing troubles :( Quote:
Cheers | Welcome to the forum, glad you joined us
Do not know too much about chain saw motors, but if you can find out the make and model....might be able to find a motor diagram online. |
09-09-2008, 02:57 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: north bend wa.
| | Re: Bearing troubles :( get a new chainsaw |
09-09-2008, 03:02 PM
09-09-2008, 03:57 PM
|  | minor bike philosopher | | Join Date: Jan 2008 Location: north carolina
| | Re: Bearing troubles :( man you have more courage than me. good luck with your project and welcome to the forum |
09-10-2008, 02:23 AM
| | Re: Bearing troubles :( CHeers and thanks for the welcome  Much appreciated |
09-10-2008, 03:37 AM
| | Re: Bearing troubles :( I don't know about that motor? Is that metal shavings I see in the last two pics? If so.....thats a lot of shavings  |
09-10-2008, 04:28 AM
| | Re: Bearing troubles :( I think that might be a EFCO/Olympyk motor....but not sure. You might want to take into a small engine repair shop, they should be able to help you out better.
I can see the serial # in the first pic I think  |
09-10-2008, 12:33 PM
Originally Posted by fairracing31 I don't know about that motor? Is that metal shavings I see in the last two pics? If so.....thats a lot of shavings  | Yeah, one of the screws was mpossible to get at, and i realised that there was an access hole that was filled up with saw dust, but unfortunately none of my tools fitted through, so i improvised and drilled it  , i'm gonna blast all the shavings off with the old compressor i think.
As for the serial number, here it is:
09-10-2008, 02:53 PM
| | Re: Bearing troubles :( Well I did my best but even with serial # 4540280 I still could not find anything  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:28 PM. | | | Sponsors
