Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
always look a free weedeater in the mouth.
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. I picked up my donated weedeater today. I thought I had them figured out boy was I wrong. I made ...
Old 08-16-2008, 05:10 PM
deacon's Avatar
minor bike philosopher
Default always look a free weedeater in the mouth.
I picked up my donated weedeater today. I thought I had them figured out boy was I wrong. I made my illustrations even though I never did get the motor to run. I thought I would run the symptoms by you guys to see if you had any ideas. Now I know it has multiple problems. I think I can salvage the throttle cable and thats about it.
Okay it had bad fuel lines so I change them the bulb leaked. I had a similar carb but instead of changing the whole carp I went for just the bult, (mistake,) I never did stop the thing from pour gas out through the muffler. I never could figure that out. So what would cause it to pour gas out through the muffler. I mean obviously its the carb but what would do that,
I thought it had spark but it wouldn't even start when I poured gas in the through the plug hole. Like I said I'm going to chuck it but I did get my pics made of the destruction and the putting of the mount together.
Me and the Ebike
New Novel in progress blog...
Old 08-17-2008, 07:35 AM
Bikeguy Joe's Avatar
Default Re: always look a free weedeater in the mouth.
Sounds like a ruptured diaphram or laeking gasket in the carb, don't give up yet.
Some also have a check valve/ball, look for that too.
Old 08-17-2008, 09:24 AM
deacon's Avatar
Just before I came on I pulled it over to check for spark there is spark. Yeah I think when I tried to change the bulb I screwed up the diaphram. What I have is a better carb from a ryonbi 31cc that works I'm pretty sure.
I am going to have to do some retro fitting since it is a different bulb system and I have to figure out how to use the choke from the one that is on it now, but I think I can because they all have pretty much the same bolt pattern. Just a matter of doing it and I will.
Joe have you ever tried super glue to lock nuts down. It is cheap and easy to find. That's my requirement for a product.
Me and the Ebike
Old 08-17-2008, 12:20 PM
deacon's Avatar
I switched out the carb for one from a riyobi 31cc and it started right up. I had to make a few design changes for both but it worked in the end and that's what counts. The squeeze bulb is not just hanging on the line so yes i will have to do something there before I try to ride it.
Me and the Ebike
