Won't start when hot!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I have a Dax F80 engine with 235 miles. I have a rope pull start and a SBP shifter kit.. ...
Old 04-05-2009, 04:43 PM
Default Won't start when hot!
I have a Dax F80 engine with 235 miles. I have a rope pull start and a SBP shifter kit.. The carburetor is a Dellorto SHA. It starts, runs and idles fine when it is cold. After running for a while and it is warmed up, if it dies or I shut it off, it won't start with the rope pull. I can use the pedals (probably spins the engine faster) and it starts right up. I need some help, any ideas?
Thanks, Larry
Old 04-05-2009, 05:06 PM
MB-Monkey's Avatar
Default Re: Won't start when hot!
pull starts on the small 2 stroke is known to not spin the motor fast enough. you could replace the return mech and rope and see if that helps but that cost you could prob get a new pull start.
Ride it like you stole it!
Schwinn Jaguar 26" Beach Cruiser
49cc Dax
Jaguar Install Kit Manic Mechanic
Sick Bike Parts Head Gasket, Plug Wire, NGK Spark Plug
Thanks to Hiker472 for the Avatar.
HT Assembly Process
http://www.youtube.com/watch?v=U6ZfkS20oYI
HT motor testing
http://www.youtube.com/watch?v=p8Ycvad7NN4
The Amazing Wuggie
http://www.youtube.com/watch?v=hYznGdTfiR4
http://motorbicycling.com/f3/install...html#post77935
Old 04-05-2009, 06:05 PM
I can't figure why it starts fine with the rope when it is cold and not when it is hot.
Larry
Old 04-05-2009, 08:47 PM
Bikeguy Joe's Avatar
Try using just a little choke, even when the engine is warm.
I found that even in the summer, if I shut the bikes off for more than a few minutes, they always started better with a touch of the primer, or a little choke.
Old 04-05-2009, 09:05 PM
MB-Monkey's Avatar
a cold motor is going to have more compression once the motor and parts are hot plenty of places to loose compression
49cc Dax
HT Assembly Process
HT motor testing
The Amazing Wuggie
Old 04-06-2009, 10:48 PM
2door's Avatar
I have to agree with Joe. I've found my engines always respond better with a little choke on starts, cold or hot. One cause of hard hot starts can be fuel atomization in the carb and intake. The fuel vapor actually evaporates into a very lean mixture which a little choke, (reduced air) can remedy. Good luck.
Over Youth and Skill
