| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Water damage...? Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I went through some rain...the motor quit on me
the next day , I found water (very little) in here..
07-12-2008, 10:09 PM
|  | HS Math Teacher | | Join Date: Jun 2008 Location: Arkansas
| | Water damage...? I went through some rain...the motor quit on me
now i can't get the motor started again... oh it cranks, but won't turn over on its own
suggestions?? |
07-12-2008, 10:15 PM
| | Re: Water damage...? I ride in the rain all the time....well as much as it rains in the desert..
I use RTV around the cover and the rubber seal for the wire's.
Have you checked for spark? Try to dry it out...I got mine wet one time and sprayed with WD-40. Dried it out and it fired right up. |
07-12-2008, 10:18 PM
| | Re: Water damage...? You could pull the cover off and put a light bulb right underneath it. That would evaporate any moisture. Or like fair said WD-40 will do the trick too. Those are both old tricks from back in the old distributor days..........................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
07-12-2008, 11:50 PM
| | Re: Water damage...? i'll try the WD40...
how do I check for spark? |
07-13-2008, 12:11 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: Water damage...? Hair dryer might also work.......
07-13-2008, 12:42 AM
| | Re: Water damage...? Quote:
Originally Posted by MrLarkins i'll try the WD40...
how do I check for spark? | You could pull your plug out and hold it next to your motor and crank the motor. But that's hard to do with these bike's.
I use a Spark plug tester...Pull your plug out so the motor will crank easier
It can be picked up at any local auto parts store. Or you can make one using a spark plug and aligator clips. Just solder the aligator clip to the plug.
You could also make one like Norman's.... Tester for ignition |
07-13-2008, 12:56 AM
| | Re: Water damage...? I would suspect your kill switch or external connections first.....good tips from the other fellas....
Lemme tell you, I try not to get rain in my knickers but other than that my engine gets pretty wet without issues....if I let rain completely keep me from riding, I would go whack. |
07-13-2008, 08:38 AM
| | Re: Water damage...? hmm, ok, I'm not as worried now
well, I took the head off and just rolled the bike....I didn't see any spark
07-13-2008, 09:40 AM
| | Re: Water damage...? Well dry it out, the kill switch could be wet and shorting as well. Always test spark with a known good plug...or Norman's unit.... |
07-13-2008, 09:51 AM
| | Re: Water damage...? i did use a known good plug AND I had the kill swith ground wire disconnected...what did i miss? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:46 PM. | | |
