| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Top end is gone below 70º Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Today was overcast, damp and chilly, perfect weather for a ride except the bike ran like crap. When it's ...  |
09-27-2009, 01:10 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Mi
| | Top end is gone below 70º Today was overcast, damp and chilly, perfect weather for a ride except the bike ran like crap. When it's above 70º the China Girl runs like a dream, I'm hitting 25 and not even at WOT just minutes after staring her up cold in the morning. Today it was barely 60º and damp, I had to hold the throttle wide open to maintain 25 and on a downhill run that I've hit 32+ going down I was only able to hit a top speed of 26 and it was like the engine was losing power, back off the throttle and the power would come back. On warm days it doesn't act like that until I'm above 30.
Should I move the clip on the needle down a notch and run a little richer now that it's getting colder? |
09-27-2009, 01:18 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: tucson
| | Re: Top end is gone below 70º absolutely |
| | Re: Top end is gone below 70º wrap it in a blanket. or maybe stick a thermometer in the spark plug hole and see if it has a cold. if it does, pour some cough medicine in the tank...
sorry, i've been drinking.
that's weird. these motors run so hot normally, you'd figure colder weather would be better for them. maybe try a hotter plug? less oil in the mix? if it's running cold, wouldn't you want to lean it out instead of enriching it? smaller plug gap?
everything i think of keeps bringing me back to the blanket. how cold was it? |
09-27-2009, 01:24 AM
| | Re: Top end is gone below 70º Cold enough that as soon as I found civilization again after getting lost for an hour I had to stop for coffee. lol
Already using Opti-2 @ 100 to 1 so putting less oil in isn't an option. Low end is exactly the same, pulls right up but then just hangs at 25, let off the throttle at all and the speed starts dropping off.
I'll try dropping the clip a notch and see how it runs tomorrow since it's supposed to be another crappy day. |
09-27-2009, 02:52 AM
| | Re: Top end is gone below 70º Try a hotter plug when it's cold! What plug are you using now? |
10-02-2009, 11:20 AM
|  | Motorized Bicycle Senior Member | | Join Date: Aug 2009 Location: ca
| | Re: Top end is gone below 70º Quote:
Originally Posted by foureasy absolutely | foureasy, more fuel = cooler ignition.
a leaner condition will create more heat
-deads |
10-02-2009, 12:06 PM
| | Re: Top end is gone below 70º With lower temps. you will get an INCREASE in the amount of oxygen in your mix.
HOWEVER, with rising humidity, you will get LESS oxygen in the mix.
Usually, cold damp weather will lean them out. The extra water in the air pretty much over rides the small amount of added oxygen from the cooler temps.
10-02-2009, 09:18 PM
| | Re: Top end is gone below 70º Well with opening up my muffler a bit (see silverbear's glowing muffler thread) and moving the E clip to the top notch seems to have fixed this. Rode 54 miles in 60º weather and it ran great. Even finally broke in and smoothed out 10 miles into that run. |
10-02-2009, 09:21 PM
| | Re: Top end is gone below 70º Learning something new everyday !
I have to admit these little engines are a bit different then the larger bore motorcycles im used to -- thanks for the correction (and not being an ass about it, im just learning ! )
/bow in respect
/thumbs up | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:33 AM. | | | Sponsors
