Took flywheel off....now wont start
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. On my ryobi 31cc I took the flywheel off to access the stronger mounting holes on the engine. When I ...
Old 08-20-2008, 09:36 AM
Default Took flywheel off....now wont start
On my ryobi 31cc I took the flywheel off to access the stronger mounting holes on the engine. When I put it back on it wont start now. I also took off the cylinder and cleaned it.
I made sure the gap was right and it has spark, I also made sure that everything is there and is working properly.
It just wont start, I think I got it to fire but just wont run.
Any advice would help.
Old 09-01-2008, 07:49 AM
Biker Mike's Avatar
Default Re: Took flywheel off....now wont start
Did you check the flywheel sheer key? I'm not sure about a ryobi but on most engines there is a key that aligns the flywheel and crank to make fire at the proper time. A sheered key would give you spark but not crank as the spark is not in time with the piston. I hope this helps. Good luck.
Advertisers
