| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Thottle cable to carb trouble Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. My throttle cable was working perfectly until I stupidly unscrewed the top of the carb and I guess I messed ...  |
10-10-2009, 06:22 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jul 2009 Location: chicago
| | Re: Thottle cable to carb trouble |
10-10-2009, 06:50 PM
| | Motorized Bicycle Member | | Join Date: Aug 2009 Location: New Jersey
| | Re: Thottle cable to carb trouble Quote:
Originally Posted by Hot Wheels | The spring is flat but I just don't see what pulls up the pin because theres nothing pulling on the silver spacer thing. It's just stuck in the little area where the cable head seems it should be. |
10-10-2009, 07:01 PM
| | Re: Thottle cable to carb trouble the cable end should be caught under the barrel. the silver spacer is there to hold the needle valve down and the spring holds down the silver spacer. |
10-10-2009, 07:56 PM
Originally Posted by Hot Wheels the cable end should be caught under the barrel. the silver spacer is there to hold the needle valve down and the spring holds down the silver spacer. | Yes ok but doesn't something get pulled and released that compresses the spring. The throttle cable just pulls and doens't return I feel like I'm missing a part because I have it together and it still doens't work. |
10-11-2009, 01:26 PM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Farmington, MI
| | Re: Thottle cable to carb trouble Your pictures won't load but I suspect you have the order correct. Throttle end through the cap, through the spring then through the slot on C clip and E clip (on pin) then through carb slide.
I suspect that your problem is orientation of carb slide. Make sure the slot in the carb slide is aligned with the pin inside the carb. Assemble it wrong and it will technically go together but not work properly. Carb slide will be locked up resulting in WOT and no throttle return. |
10-11-2009, 06:17 PM
| | Re: Thottle cable to carb trouble Also, I have had to sand down a few slides that were just too tight.
10-11-2009, 07:18 PM
Originally Posted by bseelbach Your pictures won't load but I suspect you have the order correct. Throttle end through the cap, through the spring then through the slot on C clip and E clip (on pin) then through carb slide.
I suspect that your problem is orientation of carb slide. Make sure the slot in the carb slide is aligned with the pin inside the carb. Assemble it wrong and it will technically go together but not work properly. Carb slide will be locked up resulting in WOT and no throttle return. | Yeah I think I did it right but I gotta find some lube for it and it was workig fine before so I don't think it's too tight but I could be wrong. |
10-13-2009, 04:25 AM
| | Re: Thottle cable to carb trouble There is a pin inside the carb neck. There is a slot down the side of the carb slide. When you put the slide in the carb the slot has to line up with the pin. Put the slide in the carb and rotate the slide till you feel it drop down over the pin. Look thru the carb to make sure the slide is all the way down closeing the carb throat before you screw the top on.
__________________ Put something FUN between your legs.. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:32 AM. | | | Sponsors
