| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Stripped threads Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. The threads one one of the exhaust stud holes is stripped out. My dad told me to use safety wire ...  | |
10-20-2009, 01:04 AM
|  | Motorized Bicycle Member | | Join Date: Mar 2009 Location: Phoenix, AZ
| | Stripped threads The threads one one of the exhaust stud holes is stripped out. My dad told me to use safety wire to make a "redneck" helicoil, but it didn't work. I just got it all back together and i really don't want to take it apart. Will a helicoil work in there because i don't see how a tap can get all the way into it. Or can I use some kind of epoxy type stuff to "glue" the stud in place.
Thanks,
Mrakulous  |
10-20-2009, 01:12 AM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: colorado
| | Re: Stripped threads Can you tap it out to the next bigger size, say from a 5mm to a 6mm. |
10-20-2009, 10:09 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: ny,ny
| | Re: Stripped threads Why not use JB Weld? Just kidding, that is ridiculous.
Re-tapping to 7mm or 1/4" is the only reasonable fix. |
10-20-2009, 11:14 AM
| | Re: Stripped threads If tools are an issue a sheet metal screw the right size works. |
10-20-2009, 05:54 PM
| | Re: Stripped threads Quote:
Originally Posted by bandito If tools are an issue a sheet metal screw the right size works. | If your talking about self tapping sheet metal screws that would be a bad choice. Unlikely you'd get out of the driveway. Allthread or a bolt with head cut off makes more sense. |
10-23-2009, 01:53 AM
| | Motorized Bicycle Newbie | | Join Date: Jul 2008
| | Re: Stripped threads timesert thread repair worked great for me several HT engines. |
10-25-2009, 09:48 PM
| | Re: Stripped threads Xlite Ive had some pretty crappy cars back in the day the kind youd pay $300 for and drive them till they died. I remember a few times where a 8mm bolt would strip out doing a water pump or what ever and I used a sheet metal bolt, the kind where it has huge threads on them to repair it. They dig into aluminum really well especially if the thread is just bigger than the hole. Doing it right? No but tools and money were an issue, I used what I had and it worked. I wouldnt do it now but its an option. |
10-26-2009, 01:44 AM
| | Re: Stripped threads timesert kits are what, 80 bucks? might as well buy a new engine.  |
10-26-2009, 02:18 AM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: Momence, IL
| | Re: Stripped threads Quote: |
| There are blind taps (also called bottom taps) that can thread a not-all-the-way-through hole.
My $20 Harbor Freight tap & die set has gotten a lot of use, mostly on aluminum. At that price you could buy two sets and chop down the tap on one set to make your own blind tap, if the need arose. When chopping it, you would have to be careful not to overheat and ruin the hardness of the steel.
10-27-2009, 05:58 AM
Originally Posted by bandito Xlite Ive had some pretty crappy cars back in the day the kind youd pay $300 for and drive them till they died. I remember a few times where a 8mm bolt would strip out doing a water pump or what ever and I used a sheet metal bolt, the kind where it has huge threads on them to repair it. They dig into aluminum really well especially if the thread is just bigger than the hole. Doing it right? No but tools and money were an issue, I used what I had and it worked. I wouldnt do it now but its an option. | It might be possible to get away with it on a car water pump but considering the difference in vibration, shear, and tensile forces on a HT exhaust unlikely to last more than a few minutes. Look how many fine thread studs fail. Sheet metal screws? Yeah..right! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:21 AM. | | | Sponsors
