Stripped threads
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Originally Posted by a-dam There are blind taps (also called bottom taps) that can thread a not-all-the-...
  #11 (permalink)
Old 10-27-2009, 06:02 AM
Default Re: Stripped threads
Originally Posted by a-dam View Post
There are blind taps (also called bottom taps) that can thread a not-all-the-way-through hole.
My $20 Harbor Freight tap & die set has gotten a lot of use, mostly on aluminum. At that price you could buy two sets and chop down the tap on one set to make your own blind tap, if the need arose. When chopping it, you would have to be careful not to overheat and ruin the hardness of the steel.
I'm thinking a regular tap may work better because it will bind at the bottom making the fit tighter. This proved to be true when bolting flywheels to the shaft on my Homelite friction drive setups. The blind taps came out, the regular ones didn't.
  #12 (permalink)
Old 10-27-2009, 12:15 PM
Am I missing something? Why would you want your tap to bind in the hole being tapped?
  #13 (permalink)
Old 10-28-2009, 07:10 AM
Sorry. Not the tap. The stud. Tighter the stud holds the better.
  #14 (permalink)
Old 10-31-2009, 08:46 AM
JD-StukNchaoS's Avatar
Just drill n tap to a size up making sure it's course thread and red locktite. If one is already jacked then the others not far behind,.,.,.do 'em both! Keep it simple,. GL Stuk
Nothing runs like a deere
