| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Spark Problems Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I recently determined my CDI [i]and[i] magneto were bad so I replaced both. Now with the replacement parts ...  | |
02-11-2009, 06:13 PM
| | Motorized Bicycle Member | | Join Date: Oct 2008 Location: Pennsylvania, USA
| | Spark Problems I recently determined my CDI [i]and[i] magneto were bad so I replaced both. Now with the replacement parts installed I only have spark with the plug out while i'm holding the plug...  which shocks me mind you... HELP PLEASE!!! |
02-12-2009, 01:26 AM
| | Motorized Bicycle Member | | Join Date: Jul 2008
| | Re: Spark Problems If your getting bit when it's out, should mean it is sparking in engine. Did you change plug and wire ? Wire may have a break in it when positioned different. Is is getting fuel. What kind of engine ?
Hang in there. |
02-12-2009, 10:50 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2008 Location: Arizona Bullhead
| | Re: Spark Problems How did you determine the cdi was bad?
Do not allow the plug to spark ungrounded.
With the sparkplug wire connected to the plug. Firmly press the threaded part to the bare metal cooling fin while watching the spark plugs GAP. Now let the clutch out. Gently push the bike forward. Did you see a spark??? Keep trying until you either see a spark or you are sure you did NOT .
You will probably wind up buying another cdi. |
02-12-2009, 01:12 PM
| | Re: Spark Problems What plug and wire? |
02-12-2009, 09:07 PM
| | Re: Spark Problems Quote:
Originally Posted by biken stins If your getting bit when it's out, should mean it is sparking in engine. Did you change plug and wire ? Wire may have a break in it when positioned different. Is is getting fuel. What kind of engine ?
Hang in there. | Yeah i purchased a high performance plug and wire. It is getting fuel... I can smell it when i push the bike with the plug out. It is an 80cc Chinese engine from BoyGoFast. |
02-12-2009, 09:12 PM
You will probably wind up buying another cdi. | I tested the CDI and magneto with a meter and compared them with readings people got on this forum. I got open for all readings concerning the blue wire on both the CDI and magneto. Which would mean that they're both bad. I got back from work late today so I was unable to try your idea. If I don't get a spark does that mean the brand new CDI is bad? When it sparks while i'm touching the threaded part of the plug, my left hand which is holding the handlebar sometimes also gets shocked. I'm puzzled. I have the black wire of the magneto on the lower left screw that holds it in... is that correct? |
02-12-2009, 09:29 PM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Ontario
| | Re: Spark Problems Seeing as you have the same problem as you began with, I would be asking myself if it was something else right from the start. Wiring? |
02-13-2009, 11:23 AM
| | Re: Spark Problems If you are getting spark while grounding yourself to the bike, you are getting spark while the plug is screwed in.....
__________________ If it ain't broke, and you mess with it long enough, it will be.
02-14-2009, 03:50 PM
| | Re: Spark Problems Thanks for the help everyone I finally got it up and running yesterday. Only thing now is it runs kinda rough at full throttle - seems like it bogs down. Any ideas? |
02-14-2009, 05:57 PM
| | Re: Spark Problems is it running a little rich? mainjet size might be too big. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:55 PM. | | | Sponsors
