Rough Riding at lower speeds
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. For some reason now in the last couple days only it's riding rough from 15 kph - 30 kph. Once ...
Old 03-02-2009, 10:58 PM
Mopedamauter79's Avatar
Default Rough Riding at lower speeds
For some reason now in the last couple days only it's riding rough from 15 kph - 30 kph. Once It goes past 30kph it's smooths out and rides normally.. I checked everything and the engine does not appear to be loose and everything looks normal.
Old 03-03-2009, 05:48 PM
Pablo's Avatar
Default Re: Rough Riding at lower speeds
It could be a number of things, but since it's running fine at high RPM's I think it must be fuel. I think you are past the break in stage, right?
If so, it could just be running rich. I would say run it hard for awhile, until it's good and hot. Then run full throttle for a minute of so on the way home, shut it off and glide in. Allow the engine to cool and look at the plug. Report back. Black dry/wet plug? Light tan? Glazed?
Old 03-04-2009, 03:29 AM
I took the spark plug cap off and looked at the spark plug and it looks normal to me. I don't have the tool to remove it and look at the end going into to the engine. What socket would do this ?
Old 03-04-2009, 07:16 AM
Pablo's Avatar
Not sure what to say. You'll need to look at the business end.
A spark plug socket (13/16"). One lousy one comes with the engine kit.
Old 03-04-2009, 09:39 AM
Bikeguy Joe's Avatar
Yep, the tool that comes with the kit will do it. Once you get it out, it should be from a chocolate brown to a (lightly) oily black.
If you've run the stock plug for awhile, you may just need a new one.
SPARK PLUG CROSS REFERENCE
About 3/4 of the way down, you'll see the NGK B5HS, or any of it's equivalent plugs....buy one from a mower shop, motorcycle store, or even SBP has them.
Old 03-04-2009, 02:15 PM
Well lucky for me I ordered one from Pablo. I have the b6 version of spark plug. I will go to Canadian Tire and see if I can find that deep socket. I will take to carb cover off and clean out the air filter again and see if that helps. The spark is only a few months old so I don't think it would be time to replace one already but then again I have started it up alot under pretty cold temp. Who knows. I'm still learning about these engines. I have learned quite abit from when I first got one.
Old 03-04-2009, 06:12 PM
UPDATE: I found the exact kinda of spark plug I needed at Canadian tire today. I also got a device made for removing spark plug's. It's called a spark plug tool and it's 13/16.
Waiting for the engine to cool down and then I will check the plug and post my findings.
Old 03-04-2009, 11:31 PM
I got the spark plug out and I put in a new one just for the sake of it. Anyway this is what the spark plug looks like that I pulled from the engine.
  #9 (permalink)
Old 03-05-2009, 09:47 AM
So, how does it run with the new plug?
  #10 (permalink)
Old 03-05-2009, 01:33 PM
I dunno yet.
