the reason your gas cap leaks...
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. there is a small vent hole near the top of the gas cap, more or less hidden by the gasket (...
Old 09-10-2009, 10:47 PM
bairdco's Avatar
Default the reason your gas cap leaks...
there is a small vent hole near the top of the gas cap, more or less hidden by the gasket (see photo.)
when your tank's full, the four holes on the bottom of the cap are submerged in gas, and that creates a siphoning effect, and causes the gas to leak out of the vent hole, all over your tank, your leg, your carpet, dog, etc.
if you plug it up with something, you're gonna seal the tank and cause vapor lock, so that won't work.
if you buy an aftermarket cap, like the chevy oil caps, make sure you open it up during rides to vent it, or again, vapor lock.
the best thing to do, is throw that tank in a fire and buy or make one that doesn't look like, well, a crappy china peanut tank.
i've got a pacer moped tank on the way. i'll let you know how that works....
Old 09-11-2009, 02:30 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: the reason your gas cap leaks...
Or, you can only fill the tank 3/4 of the way... (Then it won't spill out)
Old 09-11-2009, 04:17 PM
Cabinfever1977's Avatar
i only put a liter in my tank and i have a rubber oil cap. i drilled a hole in center of cap and stuck a thin metal line threw hole for venting.when i bring bike inside i can block off the vent.
Old 09-11-2009, 04:44 PM
i fill mine about halfway and i still get a little bit on the outside of the tank. doesn't really bother me.
Old 09-11-2009, 05:16 PM
Kevlarr's Avatar
I don't think that's entirely right because mine leaks even if the tank's only 1/3 full.
I took a good look at the neck and I think that's where the problem lies. The area on the neck where the tabs from the cap go in isn't at all flat and there isn't much for the gasket to seal to, that and the fact that the rubber gasket is tapered to the outer edge so it's thinnest where it needs to seal the most. Also whenever I remove my cap the entire bottom of the gasket is wet but the top is relatively dry.
Even if the holes were below the level of the gas it wouldn't siphon because of the holes where the locking tab goes through.
Old 09-13-2009, 10:10 AM
discountscooterparts.com has locking gas cap...17.00...heavy duty and dont leak and stops the varments at work from getting into the tank...ha...Dennis
Old 09-13-2009, 10:26 AM
Srjeeper's Avatar
Dennis, are all their gas caps the same size as those used on kit tanks? The B2 non locking cap looks like it should do the job providing it's the correct size. That one does not extend down into the tank yet it's still vented.
Bill
Old 09-13-2009, 10:34 AM
the cap i use from them is item#169...i have them on all three bikes...for over a year...paint them black and they are a great addition to your bike...Dennis...oh to answer your...da...i would asume so...
  #9 (permalink)
Old 09-13-2009, 03:48 PM
azbill's Avatar
their site says out of stock
Bill
www.ezmotorbike.com
azgrampa@gmail.com
  #10 (permalink)
Old 09-13-2009, 04:10 PM
Srjeeper's Avatar
I just ordered one of they're B2 scooter caps (item 191) to see if that stops the leaking.
I'll post the results after I give it a try.......film at 11......
Bill
