Stock Market Cats Alternative Energy
Rear Sprocket Slipping
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Howdy its mick29 here I recently bought a 40t rear sprocket with a mounting carrier that clamps to the rear ...
Old 12-04-2009, 12:44 AM
Default Rear Sprocket Slipping
Howdy its mick29 here I recently bought a 40t rear sprocket with a mounting carrier that clamps to the rear wheels hub ( im shaw youve all seen them ) my problem is it keeps moving very slowly round the hub ive tried retighten it but still moves Has anyone had the same problem and how can it be fixed Is there a glue or something to just stop it slipping that little bit Thanks mick29 PS HAPPY RIDING
Old 12-04-2009, 05:23 AM
K.i.p's Avatar
Default Re: Rear Sprocket Slipping
Just a couple thoughts on this. I would sugest conferming the fit of the adaptor to the hub. Use a sharpy to mark up the inside of the adaptor and then fit each half to the hub and rotate it back and forth, inspect the inside of the adaptor for contact to the hub. If it is a good fit the ink should be scuffed fairly evenly. If the adaptor is too big you will see one contact point in the center of the radius, if it is too small the outside edges will show contact.
That being said and assuming you have aprox. 80% contact or better, you might consider some double sided tape. (We actually have machined parts with this stuff). If you have a good fit and tighten the adaptor over the tape I dont think it is going to slip, I reckon you end up with six square inches of purchase, traction, or grip.
It sonds like some locktight could be used on the bolts. Get your chain alignment set up, then locktight one bolt at a time.
Discalimer: These are just common sense assesments not based on an actual application. Hope it might help.
Old 12-04-2009, 05:25 AM
bairdco's Avatar
a guy who makes cool bikes
cut up some shims out of a beer can.
Old 12-04-2009, 05:38 AM
K.i.p's Avatar
Oh sure, throw beer cans and handlebar seat posts at it! Kidding man.
Old 12-04-2009, 11:24 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
The 'beer can shim' is a stellar idea!!!
Wrap the wheel hub in strip or two of the can & mount the hub adapter onto that... problem solved!!
"Good bikes aren't cheap, & cheap bikes aren't good!"
For bicycle engine kits & bike service in Los Angeles, visit us at- www.VeniceMotorBikes.com
Old 12-04-2009, 12:38 PM
azbill's Avatar
gives you an excuse to sacrifice a brewski...for the bike !!!
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 12-04-2009, 04:09 PM
K.i.p's Avatar
..a Pabst-e-traction drivetrain. I don't understand how a shim would solve the full range of possable scenerios but ...*crack-pop,..*fzzzzzzz.......never mind.
Old 12-04-2009, 04:10 PM
Thanks for all your help guys I will try the beer can Sounds like thirsty work I wonder how many beer cans will fit? Thanks mick29
Old 12-04-2009, 07:36 PM
2door's Avatar
I'd start with a twelve pack and move on from there.
Over Youth and Skill
Old 12-04-2009, 08:23 PM
bairdco's Avatar
beer can shims work great when your handlebars strip out too...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
