Rear Gear Help!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Hello all! Just wanted to say hello and ask a quick question. I just been reading this site for awhile ...
Old 08-19-2008, 06:39 PM
Default Rear Gear Help!
Hello all! Just wanted to say hello and ask a quick question. I just been reading this site for awhile and seems awsome! So i got myself a china kit and am currently installing it on my Schwinn Cruiser! Well i am to the rear gear, and it doesnt fit over the hub. Is this correct or should i take the trusty dremel tool to it to make it slide over? I havent installed it yet for fear of bending spokes if I need to enlarge the hole some before i install it. Thanks in advance for any help.
Z
Old 08-19-2008, 07:05 PM
Bikeguy Joe's Avatar
Default Re: Rear Gear Help!
If you can grind it out perfectly on center, go for it. I usually remove the dust cap, grind off the outer flange and reinstall. It's quicker and more accurate.
Old 08-19-2008, 07:12 PM
Cool, thanks I will give that a try . Sounds much easier. Looks like i will be taking my rear wheel and gear to work with me !
Thank you!
Z
Old 08-19-2008, 07:19 PM
Don't forget to make the slight "Z" bend in the brake arm. to clear the sprocket bolts. Just give it a bend near the axle hole and another out at the tip where it fits up with the "clamp" to the chainstay.
Old 08-19-2008, 07:23 PM
Didn't even think of that. Thanks again!
Z
Old 08-19-2008, 07:37 PM
No problem....welcome to the forum!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
