| Sponsors
| Our Forums | | | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | questions abound! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. ok so i found the manual for my motor online and it says to set the idle @ 2400rpm. how ...  | |
07-25-2008, 01:55 PM
| | Motorized Bicycle Newbie | | Join Date: Jul 2008 Location: spring tx horth suburb of houston
| | questions abound! ok so i found the manual for my motor online and it says to set the idle @ 2400rpm. how do i know where that is? also, it says to adjust the main jet to deliver at high load/high rpm. how do i give a high load at high rpm and STILL adjust the carb? it is a mitsu 41cc 2-stroke 39x34 with a max of 7k rpm. help!
07-25-2008, 02:27 PM
| | Re: questions abound! The second question is easy- tune and test, tune and test.
The first question is a little harder unless you know a shop with a tune up tach that works for a single cylinder engine.
The only other way is to use an optical tach like the ones used for model planes and then your going to have to do a bit of imaginating to get it to work....but I have done it for temporary useage.
07-25-2008, 02:46 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: questions abound! I just tune by ear. When it sounds like 2400rpm, it's good  |
07-25-2008, 03:10 PM
| | Re: questions abound! Very funny.
07-25-2008, 03:26 PM
| | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: north bend wa.
| | Re: questions abound! searct tachometer they are available |
07-25-2008, 03:53 PM
| | Re: questions abound! Quote:
Originally Posted by Bikeguy Joe Very funny. | What's so funny?
I can tell you what a 4cyl at 900rpms sounds like, and an inline 6 at 700rpms...you get used to it after a while. It's not like the idle has to be EXACTLY 2400 rpms anyway  |
07-25-2008, 04:17 PM
| | Re: questions abound! ok thanks guys at least i get to "tune" it to idle low but consistent, right? as for the high rpm i have already gotten it close, in the last 3 hours of fiddling!!! btw i find this forum better suited to me than the " other one"  |
07-25-2008, 04:25 PM
| | Re: questions abound! sucking up works sometimes, also reading what has been posted on a certain idea or issue can help |
07-25-2008, 10:53 PM
| | Re: questions abound! thanks mr 13.
07-26-2008, 11:26 AM
Originally Posted by jasonh What's so funny?
I can tell you what a 4cyl at 900rpms sounds like, and an inline 6 at 700rpms...you get used to it after a while. It's not like the idle has to be EXACTLY 2400 rpms anyway  | I know you can, I can set the ultralight engines that I work on to idle around 2000. I guess I was just being a dumbass, sorry.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:38 AM. | | |
