Piston Clips?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I have a couple of jug rebuilds here, and I have not been impressed with the wire clips. Has anyone ...
Old 02-21-2009, 10:24 PM
goat herder's Avatar
Angry Piston Clips?
I have a couple of jug rebuilds here, and I have not been impressed with the wire clips. Has anyone out sourced a better after market clip anywhere. I just don not know what to think of these clips by the time I get them in they seem loose to me. I got a jumbo pack of retaining rings from Harbor Freight still not the right size.
Old 02-21-2009, 11:38 PM
Creative Engineering's Avatar
MANIC Mechanic
Default Re: Piston Clips?
The wire clips are fine...you must remove them carefully...the same way you would remove a piston ring. As long as you don't "spring" them out of shape when you remove them...They will be fine.
Jim
Old 02-22-2009, 04:02 AM
Jims right on the money with his suggestion when re using existing clips
Old 02-22-2009, 10:54 PM
Ok so its simple you guys are telling me whats your trick? Mine seem loose not as tight as the factory install.
Old 02-23-2009, 07:19 AM
You have probably stretched them, it will not take much to do that, they should fit snug back in their Goat Herder, you don't want them to wobble around like you are mentioning", I would suggest replacing them with new ones
Cheers
Brains
Old 02-23-2009, 09:15 PM
This happened to me with new clips , some special twist motion to get them in? I gave this quit a stare. Can't say I am impressed . I was using combinations of needle nose plyers, and a piece of nlyon plastic, { Its stronger than my fingernails } for the last little push.
Old 02-23-2009, 10:32 PM
Hopefully by the sounds of things its all okay now?, you are right though its not just a matter of shoving them in there willy nilly, you can hear them actually snap into place, are the components you bought from the actuall supplier of the original engines?
Cheers
Brains
Old 02-23-2009, 11:08 PM
From what I have seen weather bushed or needle bearing they are all the same clip. I do like the bushed engine over needle one seams to me they last longer. I checked mine for wear after 5000 mean miles virtually no wear at all , and it was way sturdier than the needle I am gonna check with some local small engine shops to explore alternatives just to see whats there for a clip I might like better.
  #9 (permalink)
Old 02-23-2009, 11:21 PM
I dont have any issues with roller bearings on two storkes, all 2 stroke big name brands all use them, yes the load bearing is not evenly dispursed like a bush, but the engine has far less resistance to motion inertia, and less resisitance will always allow the motor to spin more freely, I have personally never had the issue you are stating, but I must say I always change all bearings to Australian made ones, but would be interested in hearing what you find Goat Herder
Cheers
Brains
  #10 (permalink)
Old 02-26-2009, 02:04 AM
Talking Re: Piston Clips?
Went to the Yamaha bike shop asked about clips. I handed the guy my piston, he started typing in the computer. Had to explain this CH won't be in there told him what it was. He went in back for awhile , and came out with a baggy with three clips inside. I loved it they were just what I had been looking for! So I got home stare at it there perfect! I had to set that aside to replace a 5000 mile old dog on Blue. { my 5000 mile old Schwin ] Got a China 67cc from Thatsdax took jug off to look over any porting mods. WOUD"NT YOU KNOW IT IT HAD THE EXACT SAME CLIPS AS THE YAMAHA SHOP GAVE ME. my problem solved there are two styles of clips that I know of now. I wish I had a camera I would post pict.
