Not even a month old
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I pulled the cover off today and this is what I found. the big gear is striped what can cause ...
Old 02-15-2009, 05:57 PM
philymitch's Avatar
Default Not even a month old
I pulled the cover off today and this is what I found. the big gear is striped what can cause this and do you think it is still under warranty. Its the spot between the red lines.
[IMG]<a href="http://s85.photobucket.com/albums/k72/phily2555/?action=view&current=motorgearbroke.jpg" target="_blank"><img src="http://i85.photobucket.com/albums/k72/phily2555/motorgearbroke.jpg" border="0" alt="striped gear"></a>[/IMG]
Old 02-15-2009, 06:13 PM
philymitch's Avatar
Default Re: Not even a month old
sorry here is the pic
striped gear picture by phily2555 - Photobucket
Old 02-15-2009, 06:25 PM
2door's Avatar
Phily,
That is a strange one for sure.
What does the crankshaft gear, the small one in front, look like? Does it show any signs of abnormal wear? Were the gears ever lubricated? It doesn't require much, just a dab so you don't get grease in the clutch. Unless the engine block halves are loose and coming apart there is really no way for those gears to be misaligned or too far apart unles there is a problem with the engine casting or something is cracked and allowing separation. This is the first time I've seen this problem but hopefully someone with years of China gal experience will have an answer.
Over Youth and Skill
Old 02-15-2009, 06:39 PM
philymitch's Avatar
The small gear looks untouched. I also clean and regrease those gears every 5 hours of riding. Also The motor runs just fine. I took the cover off because it sounded a little dry on my ride to the store. So this had to happen within the last 5 hours of riding.
Old 02-15-2009, 06:43 PM
Pablo's Avatar
Crappy metallurgy. Probably not a lube issue.
Old 02-15-2009, 07:08 PM
philymitch's Avatar
I got the motor form zone 8 trading on jan 18 2009
Old 02-15-2009, 07:25 PM
fairracing31's Avatar
Don't the say 6 month warranty? I would send it back.
I have never seen one fail in that way.
Old 02-16-2009, 06:21 PM
Norman's Avatar
LORD VADER Moderator
I'm wondering if your clutch is a bear to operate with the clutch cable routed under the front engine mount? As for the gear stripping off its teeth is your chain real tight? You might have lost or trashed the bearing in the shaft that the clutch and rear drive sprocket are mounted on there is a bearing under the clutch and the rear drive sprocket.
Or your drive gear on the clutch was faulty from the get go.
I also noticed what looks like an exhaust leak with the oily stuff at the base of your cylinder and you might even have an intake leak quite a bit of poo around the intake.
norms-iron-works.tripod.com
  #9 (permalink)
Old 02-16-2009, 07:15 PM
Bikeguy Joe's Avatar
Send it back under warranty.
  #10 (permalink)
Old 02-16-2009, 07:17 PM
That is one blue exhaust pipe fo'sho'!
