| Sponsors
| | | | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | NO Start Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. OK, so here is the story, I just finsihed the complete installation of the 70cc 2 stoke. After many many ...  |
07-02-2008, 03:47 PM
| | Motorized Bicycle Builder | | Join Date: Jun 2008
| | NO Start |
07-02-2008, 06:21 PM
| | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: north bend wa.
| | Re: NO Start hey 08; for the carb. take off air cleaner, look inside, is it moving all the way up and all the way down, if try to adjust cable at carb and twist grip. is the petcock open, does gas come out if you pull gas line off at carb? if all is good go to elec., disconnect kill switch. after that you can pull spark plug, pour in a little gas. put in plug and pedal..good luck and let us know mitch |
07-02-2008, 06:29 PM
| | Re: NO Start hi; is throttle moving slide in carb? does gas run out if you pull gas line off carb. pull spark plug, put a little gas in then plug then pedal. does it pop, if not remove kill wire. good luck. |
07-02-2008, 06:36 PM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: NO Start I say ditch the switch.
07-02-2008, 08:01 PM
| | Re: NO Start Some of these engines need a little help making compression when new. The piston ring has not seated yet. To help it out on first start, Try pooring a little less than a cap full of your favorite 2 stroke oil down the spark plug hole. throw the plug back on and fire that baby up quick. I think that should be a step in the instructuions myself.
If your not sure, ask a friend first!   |
07-02-2008, 08:04 PM
| | Re: NO Start Take plug out, hold against cylinder head carefully - turn engine over - got spark? |
07-02-2008, 11:38 PM
| | Re: NO Start OK thanks guys i will do that tommorrow. How do I turn the engine over with out pedling.  |
07-03-2008, 05:27 AM
| | Re: NO Start Quote:
Originally Posted by Bikeman08 OK thanks guys i will do that tommorrow. How do I turn the engine over with out pedling.  | Elevate the bike. NO spark plug in hole - should turn over easily. |
07-04-2008, 05:34 PM
| | Re: NO Start hi; i just posed a question about an old school bike stand. if you had one it would be able to push it down and raise rear end of bike straight up, enabeling you to get on and start your bike, or at the least spin the motor over for diagnosis and tuning. maybe someone will know where they are. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:06 AM. | | |
