| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | New here and got a problem Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. First off, This is a great site! I am very impressed with everyones builds.
I bought a beach cruiser with ...  | |
10-14-2009, 12:24 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: socal
| | New here and got a problem First off, This is a great site! I am very impressed with everyones builds.
I bought a beach cruiser with an engine installed (80cc/66cc) and everything was fine. went about 30mph on flats and about 22mph up hill (bicycle computer). Then I blew the lower rod bearing and away went that motor. I just picked up another motor with 2 hours on it so its pretty new. I put it on my bike and it started right up. BUT... now it feels like it has no power. It goes 20mph but wont make it up hills. I pulled the plug and its looking like its running rich. Here is a checklist of what I have done to trouble shoot.
1. Change out magneto
2. Change to ngk plug
3. Checked carb for dirt
4. Checked exhaust for build up (poopoo pipe)
5. Checked for leaky gaskets.
6. Tightened head bolts.
Im at a loss. Should I get a new carb? A new engine kit?
I have NOT tried smaller jets yet. I am waiting for some input as I have never "rejetted" something. I have however soldered and welded for a few years so I am capable of the task.
Thanks again for this fantastic forum. |
10-14-2009, 12:41 PM
| | Re: New here and got a problem Welcome....where is your C clip?
Second from the top to begin with.
Soldering the jet closed and re-drilling is easy, as long as you have the small drill bit.
.027"
10-14-2009, 12:42 PM
| | Re: New here and got a problem Also, the inevitable question, What gasoline to oil ratio are you using?
10-14-2009, 12:43 PM
| | Re: New here and got a problem Where in so cal are you? |
10-14-2009, 12:46 PM
| | Re: New here and got a problem C clip is all the way to the top (lean). Im running the same gas I was running in my other motor (91 octane 32:1 full syn oil)
Located about 45 min north of san diego. (Vista 92081) |
10-14-2009, 01:10 PM
| | Re: New here and got a problem Chances are, you might have bought a bad engine? Maybe there's a reason the last guy only had it on his bike for 2 hours??
Maybe the other guy ran it without oil in the gas?????
If not, I would check the whole bike & engine for anything new that might be 'dragging'.
It the new engine a 49cc by chance??? |
10-14-2009, 01:22 PM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: ridgway colorado
| | Re: New here and got a problem also air leaks, seem to be a big prob here i know it plauged me |
10-14-2009, 01:34 PM
| | Re: New here and got a problem "2 hours on it so its pretty new"
It may be something as simple as it's just not broken in yet - almost all of 'em 4stroke and run like **** for the first 100mi or more.
The above suggestions are all good 'uns - check for leaks, but also just ride the heck outa the thing  |
10-14-2009, 01:48 PM
| | Re: New here and got a problem i was gonna say the same thing. if it's new, just keep riding it, and don't do any mods till it's broken in.
if it still runs lousy after 3 tanks of fuel, then you've got problems. |
10-14-2009, 03:32 PM
| | Re: New here and got a problem I dont believe it has any problems (abuse, bad engine) that the last guy knew about. I also have a 3 month warranty on it so either way, Im ok.
I am going to just put some miles on it this week and if it doesnt loosen up, I will call the guy and let him know my problem.
I dont think its an air leak as its running rich, not lean. (black plug).
I might try and make the jet smaller and see how it runs. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:21 AM. | | | Sponsors
