Re: Muffler Issue I'd want to know how bad is the pedal is hitting the muffler. Some of the kit supplied mufflers require a slight bend in the pipe to clear the pedal/crank. If there is just minor interference, 1/4" or less then you should be able to clamp the pipe flange in a vice and tweak the pipe just enough to clear. Some guys have had luck drilling the flange mounting holes out to allow for some minor adjustment. If the interference is excessive then replacing the crank with a wider one will be your best bet. Another option is fabricating a custom exhaust system which can be difficult without pipe bending and welding equipment.
Over Youth and Skill |
