| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Motor has no power. Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I hope your new float solves your problem devonalcorn. I'll have to look at mine. I did, however, already ...  | |
09-25-2009, 09:39 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: Ohio
| | Re: Motor has no power. I hope your new float solves your problem devonalcorn. I'll have to look at mine. I did, however, already check the main jet and it was ok (not clogged or loose, etc). And now, the slider won't hardly move up and down in the chamber at all at any position and takes quite a bit of force to get it down in there... I'm about fed up with it.
09-25-2009, 09:55 PM
| | Re: Motor has no power. Quote:
Originally Posted by devonalcorn I have this problem, too. Are you meaning the throttle cable that goes through the little aluminum threaded cap when you refer to screwing the top on the carburetor? | I mean the large threaded cap that holds the cable adjuster in it. (the one that holds in the whole slider)
Aiko... there's a slot in the side of the slider that fits over a tiny brass pin down in the carb body, (to keep the slider straight)... If you missed the pin, the slider will stick!
also, another thing to check, is that the cable isn't kinked or has any sharp bends in it.
09-26-2009, 07:44 AM
| | Re: Motor has no power. It originally worked fine. I took it out to look at it and it wouldn't hardly go back in without quite a bit of force. Before it even gets to the pin. The slider I mean. |
09-26-2009, 10:18 AM
| | Re: Motor has no power. ok.. slide issue is resolved... still runs horribly.. |
10-07-2009, 04:11 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: phenix az.
| | Re: Motor has no power. You have a cloged muffler take it off and try it if that solves the problem then clean the baffles. Phoenix JIM |
10-07-2009, 06:02 PM
| | Motorized Bicycle Member | | Join Date: Jun 2009 Location: Salisbury East
| | Re: Motor has no power. Howdy mick29 here try adjusting the needle on the carby remove the top cap remove spring remove needle there is a small E clip on needle move it up a notch or 2 put it back together and try that it sounds as if it was running to rich mine was set to rich from the factory doing the same thing let me no how you when thanks mick29 |
10-07-2009, 06:47 PM
|  | Motorized Bicycle Senior Member | | Join Date: Aug 2009 Location: ca
| | Re: Motor has no power. Venice boy - excellent advice!
@ the OP - if you have done/looked at what VB has suggested and you still have issue,
I ll link this here as well Carburetor - Wikipedia, the free encyclopedia (ive got the link configured to shortcut to the section of interest for you & this problem )
What you mentioned in op : Runs great until rpms get higher
means you have a jetting issue. Check out the link above, and pay attention to "Power Valve" section of the Operation block. NOT what i would have referred to it personally, but its a matter of terminology.
Reason: more content added
10-07-2009, 08:13 PM
| | Re: Motor has no power. As it would turn out, I bought a new carb and it solved the problem. Even on it's leanest setting, moving the needle didn't help at all. I guess the jet in it was just too big. New carb is a little rich as well, but I think that moving the needle on it would help. I'm gonna leave it that way until I break the engine in anyway. I appreciate everyone's input. |
10-07-2009, 10:05 PM
| | Re: Motor has no power. natural ice tastes better from a keg when served on the beach.
Doesnt mean the beer isnt Natural Ice.
edit: analogy. Dig ?
Reason: snazy
10-08-2009, 04:41 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: Fallbrook, CA
Originally Posted by akio2589 As it would turn out, I bought a new carb and it solved the problem. Even on it's leanest setting, moving the needle didn't help at all. I guess the jet in it was just too big. New carb is a little rich as well, but I think that moving the needle on it would help. I'm gonna leave it that way until I break the engine in anyway. I appreciate everyone's input. | Man oh man, am I ever NOT enjoying my recent first-build. It is gutless with little to no low-end power and NO top-end power. I endure sputter-sputter-pop-cough-cough-puff wherever I go. It is hard to start, and dies easily. I have a new float, cleared jet, loosened throttle rod, etc. I have taken the carb apart and checked for soot, and whatnot. I am not pleased, BUT I will admit to not having cleaned out my brand new muffler and have not reset the factory clip on the throttle needle. I am running regular gas with an oil ratio of 16:1. I am barely into my 15th mile of miserable driving.
I hope this gets more enjoyable.  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:09 AM. | | | Sponsors
