| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | The motor is failing on high rpm Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Hi guys..
Since the motor have 2000km, i decided make some maintenance on the motor. Piston rings, polish the cylinder, ...  | |
11-04-2009, 04:08 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jun 2009 Location: Portugal
| | The motor is failing on high rpm Hi guys..
Since the motor have 2000km, i decided make some maintenance on the motor. Piston rings, polish the cylinder, did the flange mod, some RSV high temperatura as sealant on base gasket, and did some runs.
The fact is that this chick never was the same, since i opened the motor. I could run in flat @ 50km/h, now 40km/h with lots of effort...climbing a hill could past 40km/h..now 33 or 34km/h.
The acelleration on low rpm, i think is the same, but in medium, high rpm, the motor is really creepy, with 4 stroke sound
The carb has some leaks that i cannot close (i think that's is on the little fuel pump, but i dont know how i fix it)
I tried one bing 16mm, and no more leaks, the idle is really really perfect, and the aceleration was awesome (with cluth on) but when i take a ride (cluth off) the motor fails...i really dont know why :S |
11-05-2009, 11:09 AM
| | Re: The motor is failing on high rpm Thanks for the reply norman
I did this mod:
But the problem is not there, because i tried a stock flange, and the problem persists..
I thought about piston rings..i saw yesterday, that the piston rings i put are some kind of "thinners"...dont "full" the 2 spaces of them..
I dont know...
And have another problem, ever i do a run, i close the fuel valve, but when im going to take an another run, i have in the ground some oil/gasoline from the motor :S
Can be related with the primary problem?
That thing in the carb, brown?, i call the fuel pump :\
(sorry for my bad english, if you dont understand, i try to explain clearly :P )
11-05-2009, 12:49 PM
| | Re: The motor is failing on high rpm I had a problem running my carb at an angle far less extreme than yours, and the discoloration on your head looks like a sign of a massive leak... but it's a touch odd because it's usually from the head gasket so that "stain" would be lower - perhaps yer leaking from around the spark plug and/or headbolts?
The thing on the carb is usually referred to as a "primer" - sometimes even a "tickler" BTW and don't worry about air leaking there - that wont effect anything, but it combined with the radical angle of yer carb probably IS causing the puddle on the floor
4 stroking is usually a sign of runnin' rich, but I'd blame a combo of tilted carb and air leaks causin' yer heartache - at least from that pic anyway... |
11-05-2009, 03:54 PM
| | Re: The motor is failing on high rpm Thanks for the reply barelawake,
I think thats descoloration of head, it was because the sparkplug wasnt full attached.. :S
See this pictures:
You can say that the piston and cylinder are in bad conditions, but i remember that before i opened the motor, the bike was running relatevely good, so i think that brown and dark marks are not a "big" problem..
4.45cm of diameter, and 4.8cm of height - piston
What you think about piston rings? and the head?
thanks |
11-05-2009, 04:03 PM
| | Re: The motor is failing on high rpm looks like they're toasted. the dark carbon deposits on the top of the piston are normal. but the sides and the inside of the cylinder itself should be nice and shiny clean.
looks like your cylinder walls are scratched and scored. this is allowing the burnt fuel to blow past the rings, creating those brown, scorched marks.
that's not good.
did you say you put in new piston rings? they're probably the wrong size.
and when you said you "polished" the piston walls, what did you use? did you leave any abrasive residue in there? did you scratch or gouge them while re-assembling?
looks like you're gonna need a new motor.
and your carb is on way too harsh of an angle. it should be as level as possible, and the way yours is, it's like pouring the fuel out of the float bowl into the motor.
as far as the discoloration on the top, mine does that. oil leaks out through the spark plug after a hard ride, but it doesn't seem to affect mine.
looks like you're a victim of the "if it ain't broke, don't fix it" syndrome. |
11-05-2009, 04:06 PM
| | Re: The motor is failing on high rpm also, that last picture of your cylinder wall, that dark spot in the upper right hand corner looks like a head gasket leak, and it looks like there's a chip in the block right there.
also, not good. |
11-05-2009, 04:07 PM
| | Re: The motor is failing on high rpm :S
I will put all together, and run till i have money to a new one.. :\
I will do the piston skirt, just for fun a while, what you say?
@ bairdco, yes, that head bolted has been scratched, but now its good, i will clean that |
11-05-2009, 10:32 PM
| | Re: The motor is failing on high rpm It looks rough but you can run it till it dies I would try to fix the intake to a more level setting
if you can you probably need to get a stock intake or make one. I know money is hard to come by these days so sometimes you have to make do. I'd clean the piston and cylinder with carb cleaner get it as clean as you can do not use sand paper or try to hone the cylinder. some of the brown won't hurt. You might try running come castor oil for lube do get the castor oil made for engine use mix it at 32 to 1 use regular gas. You might try to lap the head and top of the cylinder with wet dry paper glued to a sheet of glass to get those surfaces flat. Use some cheap aluminum spray paint on the head gasket both sides install it wet or a little damp then torque the head down.
I've experimented with a very light skin of silicone rtv on both sides of the base gasket and the intake gasket that seems to help seal those surfaces pretty well. For the seal between the intake and carb a light coat of silicone there will also help seal that area.
I use never seize on the spark plug just a tiny dab on the threads that will sometimes help the plug to seal or replace the plug .
I try not to use the acorn nuts they can bottom out on the stud and not allow the nut to tighten on the fitting I see you have them on the intake flange.
I finished up on an engine I bought on ebay today I took the engine completely apart split the cases and glad I did I found a big amount of metal filing inside the engine along with other trash(this engine hadn't even been test ran at the factory luckily) if I would have mounted the engine and ran it it would not of lasted very long. this engine also had the acorn nut on the intake and head long story short those acorn nuts were bottomed out and the head gasket would have leaked and same with the intake manifold.I ended up doing quite a bit of work on the engine started it up tonight and I think its a keeper runs very well now I have to get it broke in and I'm using castor oil for the break in.
11-06-2009, 05:19 AM
| | Re: The motor is failing on high rpm That's really bad for a untested motor
I have another bad news...one of the four threads..has been scratched (i dont know very well the term that you use), so, the he head is only "torque down" in 3 head bolts...its creepy material :S
Yesterday i put all together, rsv realante in base gasket, exhaust and intake, did some of the skirt mod (1mm or 1.5mm) and it seemed to me that was running better. I will test better when rain stops.. |
11-06-2009, 11:26 AM
| | Re: The motor is failing on high rpm I think your saying a cylinder stud hole has striped out threads. You can get a repair kit called a ( heli coil this is a brand name) or a thread repair insert to repair damaged threads check at a auto parts store. The instructions are with the thread repair kit. You really need to fix the cylinder studs having only 3 will soon cause a leak and other problems
thread repair kits go by different names you can google thread repair and see more. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 12:54 AM. | | | Sponsors
