If you've the same performance as before you had a problem - then the compression loss (if any) is marginal.
I wouldn't worry about it, you did the right thing
Problem is - where did the lil thing that caused the scratch come from? I bet the shoddy air "filter" that came with the kit failed you and let a chunk of road grit in - replace it with a real one, like a K&N or similar.
I would like to mention I think yer runnin' a bit heavy with the oil, 32:1 is fine even with regular 2stroke oil, I'm runnin' 36:1 with synthetic - there's people runnin anywhere from 50:1 - 100:1 synthetics... but they're braver than I lol
