Kill switch momentary "ON"????
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. How do ya wire the kill switch??? I connected mine so that the BLUE wire goes through the kill switch ...
Old 07-09-2008, 08:33 PM
Motorized Bicycle Builder
Default Kill switch momentary "ON"????
How do ya wire the kill switch??? I connected mine so that the BLUE wire goes through the kill switch then to the coil. I had to hold the button in to get the engine to run. Any ideas??? Can I ground the coil wire (blue) somewhere???
I also have an annoying rattle in my exhaust. It sounds like there is a nut rattling around in the muffler. It even makes it when the bike is off and I shake the bike. Any ideas. I may have to cut it open and re-weld it.
Last edited by captainrichhill : 07-09-2008 at 08:36 PM. Reason: added more information
Old 07-09-2008, 08:50 PM
Default Re: Kill switch momentary "ON"????
hi hill; can-0-worms. on my rig a powerking the white wire goes to kill. hooking the kill wrong can fry your mag. there is a screw at the end of the pipe,remove pipe from barrel,
Old 07-09-2008, 08:54 PM
Dax 70 instructons say to use the blue wire. There is a screw at the end of the exhaust but it's also tack welded together. I would still need to cut the welds.
Old 07-09-2008, 09:37 PM
Bikeguy Joe's Avatar
MODERATOR
How to wire Chinese 2-Stroke bicycle engine
Advertisers
