Re: ignition problem please help thank you very much, but i have it hooked up like that and all im getting is a putter and no real engine start, iv went through the carbs everything is in working order, and im getting spark iv primed it, use a little starting fluid to be safe and even put a new plug in it! i even went as far as to put starting fluid in the cylinder and it did the same thing.
any ideas?
i work and repair motor cycles and small engines and im stumped this engine is brand new |
