| Sponsors
| | | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | I need help please. Chain Tensioner... Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I just got this put together after receiving it on Friday of last week....
NEW BLACK 80cc Motor Bicycle Engine ...  | |
07-29-2008, 04:46 PM
| | Motorized Bicycle Apprentice | | Join Date: Jul 2008
| | I need help please. Chain Tensioner... I just got this put together after receiving it on Friday of last week.... NEW BLACK 80cc Motor Bicycle Engine Kit Bike Gas Kits - eBay (item 260260143153 end time Jul-17-08 23:03:31 PDT)
After stripping a total of 3 bolts, it's finally all together. Can definitely tell it was made in China. Anyways, the chain idler won't stay put, and it keeps causing the chain to get thrown off of the gears. I start pedaling, let go of the clutch, and it acts like it wants to start, but I never get far enough because the chain idler moves and offsets the chain, throwing the chain off of the gears.
I don't even know how to work the choke on this thing, the lettering is in chinese, so I don't know which direction is full choke, and which is off choke. Can anyone help? I'm half tempted just to throw the whole thing away and go buy a moped.
Also, the clutch is very hard to pull in. It takes a great deal of strength to pull the lever in enough to push the locking pin down.
Thank you. |
07-29-2008, 04:58 PM
| | Re: I need help please. Chain Tensioner... Welcome to the forum. Sorry about your problems. Lots of people drill through the idler into the frame and put a self tapping screw into it to keep it from moving around...............................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
07-29-2008, 05:00 PM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: I need help please. Chain Tensioner... Full choke is up, choke off is down.
For the clutch, you may need to shorten the outer cable so you don't have any tight curves in it. Also try lubing the clutch cable.
For the tensioner...they suck. You can ditch the tensioner altogether and just shorten the chain and adjust your rear wheel to take up slack. Or, you could do something like this: Motorized Bicycle Spring Loaded Chain Tensioner |
07-29-2008, 05:30 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Corpus Christi, Texas
| | Re: I need help please. Chain Tensioner... Welcome! If you do drill the tensioner drill only one side of the tube. That part of the frame carrys a lot of weight! I would not drill the tube at all. Take the bike Minus the rear wheel to a welding shop and let them see what you want to do. A simple piece of steel can be welded to the frame to force the idler to stay put. Either on top or bottom of the frame.
No matter where you go, or what you do, there Ya' are! |
07-29-2008, 05:34 PM
| | Re: I need help please. Chain Tensioner... Wow. Thank you all very much for the replies. I am very grateful. I will probably go the route of removing links and not using the tensioner at all. That seems like it would be the best way to go. And thank you for the advice on the clutch cable. I will give all of this a shot and see what it does.  Thank you.  |
07-29-2008, 05:53 PM
| | Re: I need help please. Chain Tensioner... Just be aware that the china chains stretch a lot sometimes and you'll either need to remove another link, or find some kind of tensioner.
07-29-2008, 06:14 PM
| | Re: I need help please. Chain Tensioner... ^ what he said. I would recommend going with some type of tensioner. |
07-29-2008, 06:30 PM
| | Re: I need help please. Chain Tensioner... Got me thinking about those chains. I had a "fryed rice" chain kiss the back of my left leg a few years back. Still have the scar. If you can, get rid of that stock chain ASAP. A 415 is what I use. Most of the time they just slide off the sprockets. Sometimes they don't.
07-29-2008, 08:18 PM
| | Re: I need help please. Chain Tensioner... Shorten your chain on the motor side. Adjust your wheel for it. If the pedal side chain has slack use the tensioner there. It was what finally cured my chain problems. |
07-29-2008, 08:19 PM
|  | Master Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: I need help please. Chain Tensioner... I also would suggest the tensioner, as well as the #41 chain, sooo much better than the stock parts...And what I did for the clutch is to just lengthen the clutch arm and turn it inwards for a more direct pull, as well as replace the junk stock cable and clutch lever....
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:16 PM. | | |
