i need help my bike wont start
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. my bike wont spark when i try to start. it leaks oil out of the muffler after i try toget ...
Old 04-13-2009, 09:29 PM
Default i need help my bike wont start
my bike wont spark when i try to start. it leaks oil out of the muffler after i try toget it started. ive changed the spark plug and checked the wireing can some body help me
Old 04-13-2009, 09:56 PM
fairracing31's Avatar
Default Re: i need help my bike wont start
Welcome to the forum, glad you joined us.
Have you had it running before?
Try to disconnect the kill switch and give it a go.
Old 04-13-2009, 11:17 PM
Cabinfever1977's Avatar
how long did you have it?and how much did you use it?
Old 04-14-2009, 12:01 PM
goat herder's Avatar
I your getting a lot of product out of the exhaust pipe carb bowl over flowing? Need more info.. What is your fuel/oil mix? Does it have spark when you ground the spark plug to the head and turn the motor over? More info please..
One can do anything you set there mind to.... Do a good thing...
Old 04-20-2009, 01:54 AM
BrassoMan's Avatar
Unhappy Re: i need help my bike wont start
Hi, I think I have the same problem as him. When i try and start the engine, all I feel is the vibration of the piston moving up and down with the occasional cough. There is also a bit of blacky brown oil leaking from the exhaust.
I have checked and I am getting a spark.
I have not started the engine before, i have just installed it. I am using unleaded 95 or something rather with 2 stroke oil.
Any help would be appreciated. Thanks
I just went and rolled down a hill with the clutch engaged, the engine was noticeably warm suggesting that there was combustion.
Old 04-20-2009, 02:09 AM
DEATH4OF4's Avatar
Check The Fuel Mixture. If Its Not Broken In Use 16:1. Check The Carb For Leaks Around The Intake Manifold. Use A Ngk Plug With Proper Gap + Use A Better Plug Wire. If Its Dripping Oil From The Pipe You Probably Got To Much Oil In The Gas. Hope This Helps
I Don't Know Everything...but I Know What Works.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f34/i-need-help-my-bike-wont-7401.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 04-14-2009 07:28 AM
