| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | How many rpm's when stock Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. The average stock "red line" for these chinabuilt wonders is in the 7000 rpm arena....  | |
11-02-2009, 05:16 PM
| | Re: How many rpm's when stock The average stock "red line" for these chinabuilt wonders is in the 7000 rpm arena.
11-02-2009, 05:17 PM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: KC
| | Re: How many rpm's when stock Keep drilling!  |
11-02-2009, 05:23 PM
| | Re: How many rpm's when stock I have successfully drilled the jets on a few of these.
I have also re-tapered the needles with (cringe now!) sandpaper and a cordless drill.
| | Re: How many rpm's when stock Tim,
I am NOT a 2-stroke expert BUT this is a tuning nightmare. You can sometimes feel 10 degree temp changes.
So is this one
Guess I need to shut up and get out to the garage. |
11-02-2009, 05:51 PM
|  | Motorized Bicycle Newbie | | Join Date: Oct 2009 Location: NE FL
| | Re: How many rpm's when stock Quote:
Originally Posted by Bikeguy Joe The average stock "red line" for these chinabuilt wonders is in the 7000 rpm arena. | What are most of the guys using for a tach? I bought a tiny tach and it seems to be working ok. It has a 2.5 second delay but you get used to that. I don't think theres any way this ole girl will get another 2000 rpms though. Are you getting 7000 out of a stocker or is that after modifying it? That is what this thread was all about in the first place. I wanted to find out what some of the guys were able to get out of one after it was reasonably tuned.
Thanks
Jack |
11-03-2009, 08:27 AM
| | Re: How many rpm's when stock I have never applied a tach to one of my engines, but loooong ago and far away, the companies selling them stated that the redline was 7300.
Different engines rev to different levels, due to the vast differences in things like how well the ports match up, how closely dialed in the "carb" is, ect. Other things that affect top rpm are weight, type of tires, terrain, air density, ect.
They do rev better once broken in.
11-03-2009, 08:28 AM
11-03-2009, 11:01 AM
| | Re: How many rpm's when stock 125cc and at about 9K it starts to pull. Great fun but I've never had it on a track. The neighbors love it!
Sorry, didn't mean to highjack Drdoesit's post.
On the subject, and FYI, most street 2-strokes can be modded to pull easily over 10K.
Drdoesit, you might check your port timing, at least see that things line up as intended. I think Chinese companies have so many suppliers you can get mismatched parts fairly easily. I have found sheet metal screws right next to machine screws all holding on the same cover and often see mismatched fasteners.
Dave
KC |
11-03-2009, 12:30 PM
| | Re: How many rpm's when stock I have not had the motor apart yet. I also not sure yet if it is fair to compare these little guys with the Japanese built 2 strokes either. And I agree about the fasteners etc. Once I thought that I had blown it for a second and then it went to running again. I got home and pulled the side cover to find a spare woodruff key laying in there that had bounced up and run between the crank gear and the clutch gear. Thankfully it was not the best quality either. The motor runs pretty well all told, cranks right up hot or cold and probably will get 30 mph with 44 tooth rear and my 210 lb self on it. It's only showing 5000 to 5100 on the tiny tach and from the way it sounds it can't do much more. I have had 4 stroke bikes that would turn way over 10,000 rpms too. I am just getting started here and was curious. I appreciate all of the replys and help.
Jack |
11-03-2009, 04:30 PM
| | Re: How many rpm's when stock "I got home and pulled the side cover to find a spare woodruff key laying in there that had bounced up and run between the crank gear and the clutch gear. Thankfully it was not the best quality either."
That was funny.
And true.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:17 PM. | | | Sponsors
