| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Hmm... Bad choice on my part... Obviously was. Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. i dont think that the carb screw is going to help you...but give it a try...from my understanding ...  | |
10-29-2009, 05:53 AM
| | Motorized Bicycle Elite Member | | Join Date: Sep 2009 Location: fort collins colorado
| | Re: Hmm... Bad choice on my part... Obviously was. i dont think that the carb screw is going to help you...but give it a try...from my understanding that thing is just an idle speed adjustment...i dont know...i like the bike shutting down and not idling...but 4 stroking definately changes the sound...there is a recent thread on it with a great video that has good audio for you...check it out...(i still cant figure out how to make links yet...i know im stone age)...and for tearing a gasket...oh well...that happens all the time when you tear stuff down...not your fault...how did you break your piston ring???if you did then you need to know that you need to compress the ring before putting it in...there are ring compressers that can be bought...i doubt any are cheap...or try compressing with the smooth side of some contact paper(one of my trany building tricks)...any way good luck and keep us posted |
10-30-2009, 01:52 AM
| | Motorized Bicycle Newbie | | Join Date: Oct 2009 Location: USA
| | Re: Hmm... Bad choice on my part... Obviously was. I was being dumb and tried to put the cylinder back on and didn't realize that there was a little notch to align the ring, so I forced it on with a screwdriver (like a dumb****) and the piston ring snapped. I figured that it was just a really high tension ring or something that wouldn't bend. At least piston rings arn't pricy for the china engines.
I'll have to look into that video. Thanks for the info |
10-31-2009, 02:36 AM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: Momence, IL
| | Re: Hmm... Bad choice on my part... Obviously was. Like I said, I don't have experience with your particular motor. My motor's from a Homelite leaf blower, but certain physics are the same for any two-stroke. A too-rich condition can cause 4-stroking. I lean my mix up by turning in a mixture adjusting screw (my carb has 2). From reading other posts, it sounds like a lot of china kit motors have clip you move up or down to make the needle go farther in or out. I don't know your motor, so I'm not suggesting any specific adjustment. I just know that IF a motor is 4-stroking, it's probably too rich.
When my motor DOES 4-stroke, it doesn't rev up, then bog down. It just won't reach top rpms (and it makes the telltale sound). So I would still think your problem is with proper fuel delivery. |
11-02-2009, 04:21 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: KC
| | Re: Hmm... Bad choice on my part... Obviously was. Basics: Did you rejet the carb when you changed the air filter and added the pipe?
You very likely ran it lean. A gasket leak can do that but ill -applied mods are a more common way people grenade a 2-stroke. Do the sides of the piston look scored at all? How does the cylinder look? There should be no discernible scratching/scoring anywhere where they contact each other. Is the area on the underside of the piston dome caramel colored, black , shiney, scorched - looking? There is a lot to read and black stuff oozing is just one of them. Overall plug color is not a very useful tuning tool. Plug chops are but are beyond the scope of this post.
Adding performance parts without a basic understanding of how they work is asking for trouble. 2-strokes can be a tuning nightmare as it is and you didn't even know that (in a 2-stroke) valves are a function of ports in the cylinder and piston. That's okay but if you are intentional enough to be modding it, you should be intentional enough to understand what your changes can do to the air/fuel mix and power band. Look it up on the web and read about it. This goes for any mechanical object.
Another basic is to change one thing at a time and get it dialed-in(tuned) first, then make another mod and re-tune. Hitting the proper mod/tuning combo is like shooting in the dark otherwise. BTW, jet size in the carb is one of the main changes that need to be made to "tune" your modded engine(BEFORE you ride it wide open!). It's just one, but one that will keep your engine alive. Oh, and this has nothing to do with a drill bit. DO NOT go drilling the jet. People do it on here but ask any 2-stroker and he'll say there is no way to get an accurate jet size that way. There are at least 10 jet sizes for each increase in drill bit size you will have. Say you then need another larger or slightly smaller jet size - where were you compared to where you are after a drill bit and what's the next size you need - you won't know what jet size you just made? Jets are like a buck (and they don't go by drill size). Get a few larger sized than stock and learn how to swap them out. Start several sizes larger than stock and you might be back in business. I have rebuilt dozens of carbs and have NEVER bought a gasket or rebuild set(and I don't hack them). Take your time and you can swap jets over and over without needing parts.
Buy some Yamalube sealant from a motorcycle shop. Use it to seal your gaskets as you replace them. Stay inside the lines with this stuff, do a clean, detailed, and precise job with all you do. BTW, don't use the sealer on any carb parts.
Seriously, you really need to borrow a torque wrench. Just randomly tightening down the head/cylinder with a socket is unlikely to be even enough for an optimal seal. Sounds like a hassel but when a problem arises later, you will not know what shortcut step is at fault. And just because it fires up doesn't mean it will live long.
Clean everything as you go, many times over then right before you assemble a part. You should probably do this inside your dorm or house, whatever - not at the bike rack outside while the engine is still on the bike. Controlling the environment and not having to lean over will change the quality of your work.
A motor - even these Chinese things - are precise objects. Don't force anything and take your time. Get a mechanically inclined person or a shop to assist you if needed - you'll save money in the long run. You appear to be going 1 step forward and 2 steps back each time you mess with it. Just don't get it so goofed that you toss it and start over.
Mostly, don't ride it until it is sorted!
Tough advice, all true, and just my opinion.
Dave
KC |
11-02-2009, 12:57 PM
| | Re: Hmm... Bad choice on my part... Obviously was. dmar836, although in many ways I agree with you - honestly, these Chinese engines really are just toys.
There's a happy balance between what you've described and wantonly banging on it with a rock. While care should be used and you're absolutely right that only one mod should be tried at a time - when it comes down to it, they're $50 engines and perfect for experimentation. I couldn't think of a simpler, easier engine to learn the basics on and part of that learning is hacking stuff up to see what happens.
While I wouldn't solder and drill a jet - it has nothing to do with precision as they make great jeweler's bits perfect for such things, I'm simply too lazy to bother lol and while you shouldn't rebuild in a mud pit of course, there's no real need for the "lab coat" approach - part of the charm of these motors is being able to do a top end rebuild on the side of the road with a 10mm and $15 of parts.
Personally, I love doing dumb*** stuff to my motor with a Dremel and file - it's part of why I bought the silly thing lol  |
11-02-2009, 06:53 PM
| | Re: Hmm... Bad choice on my part... Obviously was. No, I agree with you completely but in this case it sounded like his issues were compounding the more he tried - screw drivers and all.
Trust me. I would have killed or died for a motorized bike as a kid.
I just thought he might be happier faster by going back to the stock configuration and sorting it out that way putting it together solidly.
I agree these are not Swiss watches but I just think with a little assistance from the scooter shop or other rider, he might have it back the way it was with less frustration - been there.
Yamalube would be a great thing I think and if you can beg or borrow a torque wrench you can sort of mark off a few more common problems(leaks!).
I apparently came off preachy on a few posts today (as one guy said - like the expert) - maybe I was only on my first cup of coffee. Sorry all.
I would rather help him fix it if he was local rather than dog him with info he has no need for.
I know he isn't having fun with it in pieces and this is all about fun.
Thanks for the reality check.
jonyoon21, where are you located?
Dave
KC |
11-03-2009, 04:38 AM
| | Re: Hmm... Bad choice on my part... Obviously was. mmmm cawfee
It's cool man, yer helpin' and that's the important thing! When installing these motors and even their initial run-in, it's quite common to get "swamped" by wanting/needing to fix too many things simultaneously.
I'm finding that posting help here is much the same o.O
Sometimes just stepin' back, takin' a mo to sort it out and then addressing just one thing at a time, remembering there is rarely any absolutes and just tryin' for "close enough" till everything is in it's place is the only solution.
I'm glad yer helpin' - thank you
Oh yeah, I'm boycotting Yamalube for no reason other than I live behind a Yamaha Marine dealership... and the prices are completely ri donkulous o_O ...and I like Amsoil lol |
11-03-2009, 10:54 AM
| | Re: Hmm... Bad choice on my part... Obviously was. LOL. I guess I was in a bad mood yesterday morning cause I really came off badly - I must have been ready to rant. I'm drinking my first cup now and feel fine. Midlife crisis starting at 42 maybe?
Oh, sorry, I meant the sealant - maybe Yamabond. Great stuff and I see it recommended even for a lot of 4-stroke and auto applications.
For oil, I use Castor927 rather than Yamalube. I love the smell!!!
Dave
KC |
11-11-2009, 11:47 PM
| | Re: Hmm... Bad choice on my part... Obviously was. wow, i see that there has been alot of activity here since i last checked. Sorry for the delay in responding. More midterms have been kicking my ass. They never end...
dmar836, thanks for the advice. I'm not sure I completely understand everything you've said about the whole jet size thing though - I'll have to do more research.
I got the bike running again since I last posted. I checked out some of those bog problems posts - did what they suggested - float bowl and clean air filter and all - and just slapped the engine back together (after the rings and gaskets came in). It seems to ride ok, just vibrates a bit more than it used to... must not be a good sign. Maybe I could look into that whole balancing thing. I noticed there was an abrasion on one of the counterweights (it kinda dips in just a bit). The motor wasn't fourstroking anymore though.
I'm sure that you're right about the whole modding thing. I don't exactly know what the jet size thing is all about... I've seen it mentioned on the forums with people filling and redrilling, but I doubt I'd attempt that - that I know will make things worse.
The extra mods came out of need actually some want but mainly need - the stock muffler didn't fit no matter how I oriented it, so i put some (like 4) rubber gaskets in there on the studs and tightened it in position till it couldn't anymore - after running, i smelled like burnt rubber everytime and eventually the gaskets melted together, then crumbled away after break-in. I chunked that muffler and got the expansion chamber - why not upgrade while I was at it? The air filter came because of an accident and I broke the stock one when I fell off the bike at a corner of a fountain on campus - didn't see the short step... I was lucky that nothing else got hit, the carb seemed fine. The shift kit was mainly out of want since there are some hills around here but lots of flat land as well. I'll take it more slowly on the engine mods from now on though, my wallet is feeling it now... Though bike mods such as disc brakes and more gears shouldn't be a problem.
By torque wrench do you just mean a ratchet? Tis what I've been using. Also, there are abrasion marks on the pison and the cylinder. From the way you asked about them, it's probably not a good thing. Perhaps I should try to polish it?
Midlife crisis at 42 eh? I think my gf's dad had that happen too and he rushed out and got a 600cc motorcycle, lol. He keeps telling me to just get a cheap motorcycle since it'd be less work and faster, guess he doesn't understand the fun in working with these things - I wouldn't tear apart a motorcycle unless I had DEEP pockets.
I'm actually 19 and attending the University of Texas at Arlington. Funny thing is that I've been wanting a crotch rocket for a while but seeing as I live at home and my parents are against it, now look at what I have done (my dad wasn't too happy about it, he got over it though). Must be the whole teenage rebellion thing still winding down.
I've been running the engine on mixture of 4 oz per gallon (whatever that ratio is...), perhaps I should try a richer mixture. Is it ok to mix different mixtures of gas together? I still have little over half a tank left.
The motor itself isn't running at the moment though. When I put it back together, I didn't tighten the head nuts completely and had a huge loss of power, I then tightened them with a ratchet and ended up over tightening one and apparently stripped the thread and snapped the head gasket (lucky there was an extra included). So like a dumb**** again, I tried to fix it myself and epoxied (JB weld) the headstud back into the engine (I wanted to show it off at a party hosted by my friend for some odd reason - being a dumb college kid and all, that and some friends wanted to see it after I told them about it). The epoxy dried well and it rode just fine (save for the extra vibs). At the end of the night when I got home, I noticed that one of the headbolts was missing and the stud was loose again (yet I never noticed a loss in power or any air leaking unlike before when I didn't tighten it enough). Maybe some more epoxy... Maybe some more drying time... Or retapping the hole... Don't wanna go there.
So... if I make a list of issues... There is something wrong with the balancing of the crank, there are abrasions on the piston and cylinder, (fixed the issue with the kill switch not working - changed the plug), the headstud is loose, and the jet size needs to be matched up properly.
I'm also working on a better lighting system (I want to get an engine generator and a rechargable battery pack and hook that up to a lighting system, I burn though batteries pretty quickly - as I drive to work daytime and ride to night classes) and installing an analog tachometer too (so that I don't redline the engine again - got a small nos tachometer for a 1 cylinder 2 stroke engine that hooks up via the magneto). On next paycheck, Disc brakes will allow me to save my shoes (my V-brakes suck so bad that I've been braking the old-fashioned ghetto way - with my shoes) as I have a new front hub and a disc brake system lined up for installation. I just need to have it professionally installed ( I don't want to deal with respoking the wheel). Also an 8 speed cassette and new shifter (trigger shifter wasn't working on the same hand as the throttle, grip shift on left hand oughtta do it).
Thanks barelyawake for your concern as well. I'm actually enjoying these issues with the bike. Gives me something to do in my freetime AFTER studying... of course... My gf hates my bike, says it's my second lover. haha. I just hate the waiting time for parts. |
11-12-2009, 04:00 AM
| | Re: Hmm... Bad choice on my part... Obviously was. Do you know of another motorized bike around? These engines all vibrate a LOT and without a comparison it's hard to tell if yer is worse than others or not. I always thought mine was a lil hinky till I got a chance to ride another - then I realized mine was actually a lot smoother than I thought lol
Torque wrenches come in two main styles, "bar" and "click" - both tell you the amount of pressure yer puttin' on a fastener. For example the headbolts on these motors usually require 10 - 12 ftlbs, this is such a small amount that you'll need be careful when shopping for a torque wrench that it'll read that low; torque wrench - Google Product Search
JBweld is just not gonna hold a headbolt on for long. The easiest way would be to get a stud the next size up and tap the hole to take it. Another way is a Helicoil insert, in some ways this is better as you keep the original sized fastener, but it is a lil harder to do.
Honestly I would ignore the abrasions for now unless they're so huge they're causing a loss of compression.
Another solution would be to get just another motor, they usually run 60-80 bucks without the rest of the kit, I got one myself just for parts You've learned a LOT on this one and that's worth every penny  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:16 AM. | | | Sponsors
