High revs
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. After about 300 miles my motor revs are quite high when I first start up the motor and then revs ...
Old 10-14-2009, 06:37 PM
Default High revs
After about 300 miles my motor revs are quite high when I first start up the motor and then revs down to a somewhat normal rate, but still just a tad high. I use the choke until its warmed up to slow the revs. If I put the choke to full it will cease to run which kinda makes me think it is not an air leak. I have not checked for air leaks as yet because I have run out of WD and am not really sure of any other way to check and I'm thinking it might be something else. I have not done any mods yet. Any help at all whether right or wrong is much appreciated.
Old 10-15-2009, 12:56 AM
Default Re: High revs
I took the carb off and found a fair amount of dirt granules on the bottom of the bowl. Is this normal?
Old 10-15-2009, 02:14 AM
I registered with this site awhile after I got the motor so I knew very little other then what was in the manuel so a no to the rinsing of the tank. If rust looks a lot like sand then maybe thats what it was. Cleaned it all out of course and I took off the manifold I guess its called and it looked fine. I put some form a gasket on the join anyway. I was thinking if I still have the problem, as I havn't tested it yet, if the leak could be where the carb hooks up the the manifold. Hopefully I have the wording good enough here to be understandable.
Old 10-15-2009, 04:29 AM
BarelyAWake's Avatar
In-line filters are a must with these things, the tanks are not lined, tend to be a touch rusty and mine is still spitting little bits of paint into my filter even after 700 miles lol
I shoulda lined it
It defo sounds like you got an air leak somewhere, tho I'd suggest sticking a lil o-ring in the carb where the manifold seats and checking/replacing the intake gasket with a real one (the stock ones are almost useless in most cases) - with two strokes you could be suckin' in air from almost anywhere.
Check all around both the upper and lower gaskets on the cylinder - lookin for "soot" or greasy nastiness near the head and base gaskets, often the headbolts weren't torqued properly at the factory and/or sometimes the milling process leaves a bit to be desired. Check the gasket seam where the two halves of the crankcase join and take a look at the base of the clutch's cable guide (nearest the clutch arm), this cable guide wasn't tightened enough on mine and was leaking a bit.
Lastly - there's the couple of bearing seals, look for excessive oil in your clutch housing and magneto, fortunately it's unlikely it's those with a newer motor.
Odds are it IS simply the intake manifold - specifically where the carb mounts. It's not a bad idea to keep an eye on the other stuff though
Old 10-15-2009, 09:57 AM
It did come with a filter and do use it. Purdy cool you mentioned to check for oil around the cable guide as I had noticed oil there for the last little while and that was another thing that I tightened up last night. I will be testing the motor today if the weather allows and thank you for all the great advice guys. I'll be sure to let you know how it goes.
Old 10-15-2009, 04:30 PM
Just as I suspected, it's gonna be stubborn.
Old 10-15-2009, 09:36 PM
I just finished using an o-ring as instructed on a post from bikeguy and also screwed that clutch cable guide in some more not realising that it can be scewed in too much. Thought I had got some super comression for a minute there lol. Also broke down and got some WD40 today. Calls for rain and snow tomorrow but sunny on saturday. I got time so I actually glad to have this hobby. Was looking at some welding stuff today thinking I would like to make my own creation at some point. As long as the laws don't change much or not at all in this area I will definitly be going much farther with this stuff.
Old 10-16-2009, 04:55 AM
It is an addiction lol
Any luck gettin' it to run better? Don't let rain stop ya from riding, it's a great way to test yer electrical sys lol
BTW - I wanted to mention about the only thing WD40 is good for is cleanin' stuff, as a lubricant it fails in very short order. If you want a good general purpose penetrating oil that actually lasts a lil longer try PB Blaster: Amazon.com: PB Blaster Penetrating Catalyst 16 oz. aerosol: Automotive
I know the can looks a bit odd lol - but it's all the engine techs here at the marina will use. As they're talking about combating dissimilar metal corrosion in a salt water environment - I believe em Well, that and I've used it a bunch myself and it's ossum.
I dunno what you wanna use stuff like that for on yer bike, but if it's lubrication for cables or chains I wouldn't recommend it - none of the spray penetrating oils last long enough and there's such awesome cable and/or chain lube available it doesn't seem worth it.
  #9 (permalink)
Old 10-16-2009, 10:57 AM
Thanks BA for that info and you are right. Ive known about how pitiful WD is for qiute a few years which is why I didn't have the stuff in the first place. I only bought it for the purpose of testing for airleaks. Right now I see a little sun so I will go see how the bike is running after last nights work.
  #10 (permalink)
Old 10-16-2009, 11:08 AM
Riiiight - testin fer air leaks lol duh
I shoulda thought of that man - my bad
