| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Help!! Wont start anymore!?!? Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Hello everyone, Well, to start, the bike was runnin' pretty good. Then after maybe 40 or so miles on it, ...  | |
04-03-2009, 11:21 PM
|  | Motorized Bicycle Newbie | | Join Date: Apr 2009 Location: Albuquerque
| | Help!! Wont start anymore!?!? Hello everyone, Well, to start, the bike was runnin' pretty good. Then after maybe 40 or so miles on it, it was having a hard time starting. So, i took out the spark plug, connected the sparkplug wire to it, grounded it to the motor and rollled the bike to see if there was spark. for a few feet, there was nothing. then, it sparked. did it a few times and there were times it woud and wouldn't spark. My wire connections seem good from the Mag to the CDI. I disconnected the kill switch just to make sure... and it STILL wont start. Is it possible that the CDI ... OR the mag could put out an intermittent spark? Someone Please give me some ideas. i've kinda ran out.  P thanks!   |
04-04-2009, 08:45 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: penn state
| | Re: Help!! Wont start anymore!?!? If you only have 50 miles on it and it is new the company you purchased it from may give you a replacement, the cdi wiring is pretty fragile that comes with these kits. If I was in your shoes and the spark is intermittent like you said . I would remove the wire from both the cdi and also the plug boot , cut off 1 inch of the wire on both ends and reattach it . then test the spark . If you are still having issues . Then you have one of 2 choices,#1 change the CDI unit and or the magneto unit |
04-04-2009, 09:17 AM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Ontario
| | Re: Help!! Wont start anymore!?!? I'd start with trying a new plug, the plugs that come with the kits are not the best.... |
04-04-2009, 09:18 AM
| | Re: Help!! Wont start anymore!?!? Make sure you check all wire connections, including those at the mag.
Clean the whole works with some brake or electric cleaner too.
Try a new plug.
04-04-2009, 10:55 AM
| | Re: Help!! Wont start anymore!?!? Get rid of the stock plug and wire. The stock plug is notoriously bad in many cases, yes it has worked fine for a few folks - but it's so easy to use a known good plug and wire.
I assume fuel delivery is good. Muff unclogged. Clutch not slipping. Etc. |
04-04-2009, 01:41 PM
| | Re: Help!! Wont start anymore!?!? part time spark?
Easy fix wiring check all wires connected with a good crimp connection or soldered together?
No broke or shorted connections. There is a very fine copper wire soldered to the mag coil, hard to see best to check all soldered joints at the mag coil.
Spark Plug gap try 0.020 and use a clean fresh plug. Plug wire ends on both ends nip off about 1/4" and reinstall.
Now for the bad news the cdi might be bad but they usually either work or quit.
Something else make sure the choke is off and hold the throttle wide open pedal it until you can hear it fire if it will you might of just flooded it. Do this with a clean spark plug.
Norman
04-04-2009, 02:28 PM
| | Re: Help!! Wont start anymore!?!? Always being hopeful for a cheap fix, I'd also wonder if the mag side key is broken. Not sure if it's possible but I could see this causing intermittent spark as it "freewheels". |
04-15-2009, 06:43 PM
| | Re: Help!! Wont start anymore!?!? Thanks for all the sugestions and help! SORRY it took so long for me to get back with everyone. Been working and what not. Did a little of everything. Changed out the CDI, already had a better spark plug wire. all and all.. in the end, it was the clutch lever arm. It wasn't swinging out enough to allow the clutch to grab. I can't wait for my hair on the sides of my head to start growing back after pulling them all out. |
04-17-2009, 03:45 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: Help!! Wont start anymore!?!? that would have been the first thing i would check. |
04-17-2009, 10:18 PM
|  | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Albuquerque
| | Re: Help!! Wont start anymore!?!? Hind sight is 20/20  : | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:59 AM. | | | Sponsors
