The first thing you can try that's the easiest is diconnect the kill switch..some of these switch's will ground themself's out.
If that don't work, you want to check for spark...before you do that check all you wire connection's for the CDI and make sure they are still connected.
To check for spark I use a spark plug ignition tester..
This can be picked up at any local auto parts store...you can also make one with a good plug...alligator and just solder the clip to plug
Norman has a cool one that is much simpler to make...
Tester for ignition
Be sure to pull the plug out to turn the motor easier...or just pull your plug and hold it next to the motor to check for spark...this is a little hard for me since you have to hold the plug and turn the motor at the same time..
If you got spark...then you need to see if you are getting fuel....crank the motor for a little bit then pull the plug out and see if it's wet with fuel.
If not...check the screen in the petcock...check to be sure float is not stuck in the carb bowl..
hope this help's get you going
