Stock Market Cats Alternative Energy
HELP PLEASE!!!! My spocket wont move
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Hi well im new and i somehow installed a 66 raw engine on my beach cruiser (i want it on ...
Old 12-05-2009, 03:17 PM
maciasjair's Avatar
Question PLEASE HELP New On this on the bike world...my bike chain wont move
Hi well im new and i somehow installed a 66 raw engine on my beach cruiser (i want it on my stingray but i couldnt fit it.)
However the sprocket in the wheel wont move cuz the one inside the motor wont turn
so there's no way of running my bike if i cant get the wheel to turn at all
Can anyone help me been working on this thing for 2 days well todays the third and i really want to drive it
also how do you drive it ? lol might sound silly but the only controls i see are the handle thing the looks like a brake and the red button (is that a do not press red button?)
Please help
2 stroke, raw engine, 66cc
Old 12-05-2009, 03:27 PM
bairdco's Avatar
a guy who makes cool bikes
Default Re: PLEASE HELP New On this on the bike world...my bike chain wont move
is your clutch hooked up?
Finfan's Avatar
First off do you have the clutch cable installed? That must be in place and adjusted correctly before you can engage the clutch and roll the bike. The button is a kill switch so you can turn off the engine once it is started. Wire it between the two wires that run to the CDI (black box with spark plug wire). The handle thing is the clutch lever. That should be at the handlebar end of the clutch cable. There should also be a throttle grip with a cable that runs to the carb. Good luck!
Second this is the wrong page of the forum for this type of question. Don't be surprised if the moderator moves it.
-and-
I'm not lost, I'm exploring!
Old 12-05-2009, 04:06 PM
maciasjair's Avatar
Clutch is in place well according to the manual it just run the wire thru the other thing in the cover of the sprocket ? isnt?
Well everything seems in place it just not moving
do i have to adjust the bolt where the clucht passes thru at the engine?
if so how?
Old 12-05-2009, 05:15 PM
Pablo's Avatar
Default Re: HELP PLEASE!!!! My spocket wont move
Is your clutch working?
So with no compression (plug) out - you roll the bike and piston moves? Normal.
Put plug back in (now have compression) you can't turn the engine over?
Old 12-05-2009, 05:22 PM
maciasjair's Avatar
Exactly! Thanks for writting!
well i dont how to know if its working i mean i did what the manual told me and it looks good i mean from the handle to the bronze tip with the screw is good i dont know if theres more to look for
Old 12-05-2009, 05:31 PM
Pablo's Avatar
What happens when you pull the clutch hand lever in?
Old 12-05-2009, 06:36 PM
maciasjair's Avatar
the cable brings the metal thing toward the bike's seat tube
Old 12-06-2009, 11:23 AM
Finfan's Avatar
Try using a pair of pliers for leverage and moving the clutch lever towards the engine. Does it roll then? If so you need to adjust the cable some more with the brass stop that slides over the cable and allows you to adjust the length. If it doesn't make a difference then your clutch isn't disengaging and there is something wrong inside the engine.
-and-
Old 12-06-2009, 07:26 PM
If it's brand new, you might need to take the right side cover off and adjust the clutch. It could be that the clutch is adjusted too tight from the factory.
Take the cover off. Inside, there's a little silver screw that's off center. Remove it; it's the stopper for the thumbscrew in the middle. Pull the clutch lever, and you should be able to turn the thumbwheel counterclockwise to loosen it. You'll have to play back and forth a little bit until you get it set where the clutch is disengaged when you pull the clutch lever, and engaged when you don't. Make sure to put the silver stopper screw back in before you put the cover back on, and a little blue loctite on it will keep it from falling out inside the clutch cover.
I also have a "raw" brand engine, 48cc, and I had to take the clutch entirely off in order to free the countershaft, because it was stuck from sitting on a shelf somewhere. It's really simple.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
