Hellllp! I am Sooooo Close!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. The throttle on my bike wont move when i twist. Any ideas why???? (the throttle h as to much tenision ...
Old 09-06-2009, 09:22 AM
weekend-fun's Avatar
Default Hellllp! I am Sooooo Close!
Any ideas why????
(the throttle h as to much tenision it wont go)
well, as "modest mouse" says:
Good news will work its way to all them plans.
visit my website:http://weekend-fun.webs.com/
my youtube: http://www.youtube.com/user/WeekendFunTheBiker
Blog:http://weekend-funs-garage-builds.blogspot.com/
and a GREAT new news source: http://www.newsy.com/
PLEASE join CRU St.Louis if you are near st.louis (or can afford to come here and do rides with us)
Read more at: http://crustlouis.webs.com/
Old 09-06-2009, 09:50 AM
RedB66's Avatar
Default Re: Hellllp! I am Sooooo Close!
My first instinct would be to say it is installed incorrectly. Take it off and try it again...when you put the cable on the handle you should be able to twist it and see it function properly before you install the two screws in the handle. Make sure your spring on the carb side is installed properly also.
You do not need a parachute to skydive.
You only need a parachute to skydive twice.
Old 09-06-2009, 09:54 AM
i bet. i am missing the washer thingy
Old 09-06-2009, 02:28 PM
bairdco's Avatar
did you drill the little hole in the handlebar for the throttle pin? if you did, sorry for pointing out the obvious, but i've read a few threads where someone didn't do it, they just crank it down till it breaks the plastic pin,and then the grip won't spin. you need that hole to keep the throttle-grip in place, and to keep the whole assembly from spinning, after the pin breaks off.
Old 09-06-2009, 03:28 PM
BarelyAWake's Avatar
This may not be it, but a good tip anyway - make sure all your cables have only gentle bends. No tighter than what would make a loop 4 inches across or it will bind the cable inside.
oh and lube them - they're dry as a bone fresh from the kit
Old 09-06-2009, 03:38 PM
yes i drilled it
Old 09-06-2009, 04:12 PM
Any ideas why????
If you tighten the cap to tight where the cable goes into the carb it will not work properly...good luck...Dennis
Old 09-06-2009, 04:15 PM
also is your carb slide in the right way have you had the engine started and if so is it stuck wide open if so your slide is in the wrong way make sure that tha pin is in the croove on the slide
if you dont see smoke your doin somthing wrong fly low beat the radar
04 shcwinn 80cc dax sbp camber cns carb boost bottle k&n filter 36 tooth 40mph (gps tested) havin fun and smokin scooters
  #9 (permalink)
Old 09-06-2009, 04:42 PM
MB-Monkey's Avatar
i agree with sky liner sounds like the nub is not in the slot properly. Take the top off the carb and the air filter off the carb. check that the throttle turns when out of the carb first. then reassemble correctly line up the nub in the carb housing with the slot on the slide. once installed look thru the opening from the air cleaner and you should be able to watch the slide work in the carb. i would adjust the top of the carb all the way down then start at the throttle handle and adjust back to the carb until correct.
Good luck
Ride it like you stole it!
Schwinn Jaguar 26" Beach Cruiser
49cc Dax
Jaguar Install Kit Manic Mechanic
Sick Bike Parts Head Gasket, Plug Wire, NGK Spark Plug
Thanks to Hiker472 for the Avatar.
HT Assembly Process
http://www.youtube.com/watch?v=U6ZfkS20oYI
HT motor testing
http://www.youtube.com/watch?v=p8Ycvad7NN4
The Amazing Wuggie
http://www.youtube.com/watch?v=hYznGdTfiR4
http://motorbicycling.com/f3/install...html#post77935
  #10 (permalink)
Old 09-06-2009, 08:46 PM
GearNut's Avatar
The slide could also be in up side down. More that one kit has been shipped this way.
One end of the slide is cut squarely, the other end is cut at a slight angle. the slight angled side goes down. If this is the problem, be sure to get the jet needle and retaining washer in correctly.
Some instructions do not show this correct either. It goes: first jet needle in little hole (all the way untill the needle clip bottoms out in the floor of the slide), then little washer with slot in it goes on top of the needle. then the spring.
