Re: gremlins File,
The cracked manifold certainly sounds suspicious. Is yours cast aluminum or welded steel? Whichever, try smearing some type of goo over the crack, thick grease will do, run the engine slow and see if your problem changes. Then check to see if any the goo got sucked in. If yes, and you have a steel manifold then the crack can be welded or brazed or soldered closed. If it's cast aluminum you can try Devcon liquid aluminum or steel. They have liquid titanium but I don't think you'll need it on the intake side; not enough heat.
My theory is at low engine speed you're sucking excess air into the intake making your mixture lean but at higher speed the crack isn't big enough to allow enough air to cause the same condition. Maybe I'm full of it too but cracks in intake manifolds will cause problems with any engine, Chinese or small block Chevys. Good luck and let us know what you find. Oh, yeah, about grimlins. I have one that lives in my garage. I call him "Stupid S.O.B" Everytime he steals one of my tools or moves something so I can't find it, I say, "Now what did you do with that you stupid S.O.B"
Easy Ridin'
Remember: Racecar spelled backwards is racecaR
