GAS in the MAgneto
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Ahh I opened my magneto cover for the first time ever, had the motor four months, There was a puddle ...
Old 11-08-2009, 03:43 AM
Default GAS in the MAgneto
There was a puddle of gas-oil dripping out everywhere, yuck! Lucky I still have a working magneto!!
I know there is a rubber seal in there behind the magneto wheel somewhere, Anybody know how to replace the rubber seal.
I suppose it's a common problem with frequent use...
Old 11-08-2009, 08:22 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: GAS in the MAgneto
Yep... bad oil seal!!!
If it's running good; A quick easy way to deal with it, is to just drill a small hole in the bottom of the cover to let the oil drip out... (if you don't mind the drips...)
Old 11-08-2009, 09:06 PM
2door's Avatar
As long as the motor is running good do what Venice said. When the time comes, and it will, to replace the seal, usually when the motor starts running rough, here is the only source I've found for a replacement > Motorized Bicycles Gas Bike Engines Gas Powered Bikes Motorized Bicycle Parts
You'll need to remove the magneto rotor (magnet) by removing the nut that holds it on, prying the rotor off using two large screwdrivers and 'wiggling' the rotor off the crankshaft. There is a woodruff key that you don't want to loose. Be careful removing the magnet. The crankshaft is easily bent if you apply too much force so go slow and be easy. Use a sharp tool to pry out the old seal, clean the bore before installing the new one. Find a socket that is the same diameter of the seal and use it to drive it in making sure you seat it completely into the recessed area (seal bore) where it is supposed to go. Use some oil on the shaft and the inner surfaces of the new seal when installing. The most common reason for seal failure is the original not being driven into the bore completely and the magnet rubs against it causing friction which destroys the rubber. Hope this helps. We're here if you have problems.
Over Youth and Skill
Old 11-09-2009, 01:19 AM
GearNut's Avatar
All I can add is: do not scratch the crankshaft where the seal grips against it. The scratch will create a leak and prematurely wear down the sealing "lip" of the seal.
Old 11-09-2009, 10:48 AM
DonnnN's Avatar
What causes these seal's to fail over time?
Old 11-09-2009, 12:50 PM
2door's Avatar
In a perfect world, and in theory, the seals should last a very long time but in reality they simply wear out. Microscopic solids that move with the oil/fuel work on the close tolerances in a shaft seal eventually wearing down the 'lip' or sealing surface. In our application heat from combustion also promotes deteriation of the rubber seal.
Sometimes, as I stated above the cause of seal failure, especially premature failure is due to the seal not being installed correctly at the factory. If it is not driven completely into the recessed area designed for it the magneto rotor will rub against the outer lip quickly wearing it out and causing failure. Another reason was also given here. Any scratch or surface imperfection on the crankshaft will quickly damage a seal.
Interesting side note here is the unavalability of replacement seals. The factorys that produce the 2 stroke engines apparently have them made especially for these engines. I did extensive searching for a replacement and the closest I could get was a place that would custom make them but they would only make them in quanity. $300.00 for the first 5 seals, and you had to order 300. You could replace your engine much cheaper than that. One of our sponsors is the only source that I've located for shaft seals for the 2 stoke engines. Motorized Bicycles Gas Bike Engines Gas Powered Bikes Motorized Bicycle Parts If anyone knows of another supplier please let us know.
Old 11-20-2009, 04:11 PM
Thanks for the link. I have been trying to replace the nut I striped on the crank, now I have found what I need.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f34/gas-magneto-12800.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 11-08-2009 11:15 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
