Stock Market Cats Alternative Energy
fuel wont ignite.
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. well, it seems like my bike just keeps getting more and more problems if i ride it more and more, ...
Old 12-06-2009, 06:12 PM
Question fuel wont ignite.
well, it seems like my bike just keeps getting more and more problems if i ride it more and more, today when i tried it out it started out fine. and i drove a little. but later when i was gonna try it out again it just wouldnt start. i check if there are a spark. and yes there is. i check if i got gasoline. yes i do. so for me it seems like the fuel wont ignite or something. but what do i know...
Old 12-06-2009, 06:25 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: fuel wont ignite.
Is your choke lever on the carb up or down when you try to start it???
Put it down, pedal as fast as you can, "pop" the clutch & keep pedaling while "milking" the throttle lever.... it will start!!!
Also, mix your gas / oil at 24:1 for the break in!!!
"Good bikes aren't cheap, & cheap bikes aren't good!"
For bicycle engine kits & bike service in Los Angeles, visit us at- www.VeniceMotorBikes.com
Old 12-06-2009, 06:33 PM
the choke lever is down, so it is off, and i did pedal and milking the throttle lever forever today, but it wouldnt start. can try again tomorow. and is the 24:1 oil mix in gallons. if it is. please tell me what it would be in liters.
Old 12-06-2009, 06:47 PM
Try taking your spark plug out and to see if it is wet. If it is wet, then it may be fouled out. I have had fouled out spark plugs that will still spark, but not good enough to run the engine. If your plug is wet, try putting in a new correctly gaped plug before you start messing with anything else.
Old 12-06-2009, 06:58 PM
Welcome to Smart Conversion | Online Unit Conversion and Calculation
Old 12-06-2009, 08:23 PM
Cabinfever1977's Avatar
the choke lever should be up when starting,then put the choke down after a minute.
Old 12-07-2009, 04:30 AM
BarelyAWake's Avatar
Cabinfever - that may be true for your bike, but as I think he's flooding it trying to start as it is I don't think making the mix even richer is gonna help. That's a good recommendation if he was getting partial ignition but then it'd sputter and die. I only mentioned that because although my bike runs great through the whole range and I've got my mix as close as possible - it flat out hates the choke and wont run with it on, not even sputter - even bone cold. I just use the primer to give her some and that works fine. *shrug* I could be wrong, alla these bikes are a lil different with a personality all their own lol
dytesaft - Is your bike even trying to fire or nothin' at all? As others have said, check for spark and fuel - should you have both it should run. If you've flooded it badly, holding the throttle wide open while turning the engine over sometimes helps to get her to fire.
Most of all - speed counts, pedal up as fast as you can before letting the clutch out and keep pedaling - these magnetos are awful weak and at low speeds they don't put out much.
Old 12-07-2009, 09:33 AM
i tried with a new spark plug, but with no luck, i will go out and try it soon.
Old 12-07-2009, 10:01 AM
DonnnN's Avatar
Choke lever.. Remove the 2 screws holding the air filter on the carb.. Check the choke lever.. The nut might be loose and it might just be stuck at full choke but you'll see the lever as all the way down thinking that its not choked..
AIR FUEL AND SPARK.. Thats all you need.. So im guessing thats your problem if you already changed spark plugs..
Good luck man..
Old 12-07-2009, 10:05 AM
will check out the choke now, and try to start it up.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
